10" table saw for making turning blanks
Forum topic by Lisa Chan posted 02-19-2010 10:31 PM 3751 views 0 times favorited 20 replies Add to Favorites Watch
View Lisa Chan's profile
Lisa Chan
147 posts in 3113 days
02-19-2010 10:31 PM
Topic tags/keywords: table saw question lathe
There are lot of posts in the past few days about table saws, accuracy, and everything. So, I feel a little lame about asking a somewhat (but not entirely) redundant question.
Mine is specific.
I have LIMITED space. My general need is to make 2×24 inch blanks into approximately 1×12 inch blanks. I have a mitre saw for chopping the blanks down from 24inches to 12inches.
I will (maybe once a month) be ripping 3-4 hardwood boards no wider than 8 inches, longer than 2 ft, or thicker than 3” down into smaller pieces. I can also cut down the length first with the mitre saw before running them over the table saw
None of these things will be used for fine cabinetry. I’m focused on woodturning and making spindle blanks.
My question is… if I buy the nicest blade I can afford and pop it into a Skil table saw
like this guy from Lowes for $179
http://www.lowes.com/pd_197823-46922-3400-12_0_?productId=1229557&Ntt=skil%20table%20saw&Ntk=i_products&pl=1&currentURL=/pl__0__s?newSearch=true$Ntt=skil%20table%20saw$y=0$x=0
Am I making a decent choice for my specific application? I don’t have $600, but I do have $300.
-- Lisa Chan, custom cafts and yarn accessories, http://www.grippingyarn.com
20 replies so far
View John Steffen's profile
John Steffen
218 posts in 3018 days
#1 posted 02-19-2010 10:50 PM
I don’t see why you couldn’t use a small/cheap table saw to do what you want.
Is there any reason to not consider a small band saw? Like the Jet JWBS10OS ?
-- Big John's Woodshed - Farmington, IL
View KayBee's profile
KayBee
1083 posts in 3209 days
#2 posted 02-19-2010 11:37 PM
I actually have an earlier version of that saw. I just can’t seem to part with it. It’s used as an outfeed table at the moment. You can find them really cheap on craigslist, like $40-$60 around denver. It comes with a serviceable carbide blade. So if your just cutting for turning, you don’t really need a better blade. Might consider ripping first, then crosscutting on the table saw with the miter gauge. A little safer than ripping little bitty pieces.
-- Karen - a little bit of stupid goes a long way
View MrHudon's profile
MrHudon
114 posts in 3173 days
#3 posted 02-19-2010 11:40 PM
Sounds like a band saw would be a better option for the types of cuts you want to make.
-- Mark, www.mrhudon.com
View NathanAllen's profile
NathanAllen
376 posts in 3107 days
#4 posted 02-19-2010 11:49 PM
I second the band saw option. The small benchtops would work fine or if you dedicate more space for a 12” or 14” model it could let you expand into box making and other projects.
Then you have the cheapest solution, a nice pull saw would allow you to tear through the wood in a couple minutes. Clamp on either side, trace a scroll line and pull away. I say pull saw because to me the idea of using a hacksaw to draw a straight line is absurd.
View JJohnston's profile
JJohnston
1622 posts in 3254 days
#5 posted 02-19-2010 11:57 PM
I disagree with the bandsaw option. If all you want to do is rips to make turning squares, a saw like you link to and a narrow push block will do you fine. Really, you don’t even need to upgrade the blade, since you’ll be removing the surface left by the table saw as soon as you start turning anyway. You can also use the table saw with the blade tilted 45 degrees to take the corners off your blanks to get a head start with the rounding. No fuss, no muss – just push ‘em through.
Edit: you can upgrade the blade for its longevity, but cut quality is irrelevant.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View woody57's profile
woody57
650 posts in 3390 days
#6 posted 02-20-2010 02:42 AM
I think the table saw you mentioned would work fine. A small band saw would also work fine. It’s really your choice.
-- Emmett, from Georgia
View Jonathan's profile
Jonathan
2608 posts in 3013 days
#7 posted 02-20-2010 02:47 AM
For ripping, I vote for the TS. And I also agree with KayBee that you might want to consider ripping them first, then crosscutting on the miter saw… just seems safer this way in my mind.
It seems like a Shopsmith is a bit large for the space he wants to devote to this.
I believe Lowes puts that saw on sale fairly often and if I recall, it was maybe $99 on Black Friday last year? Not that you want to wait that long though.
I’m sure Craigslist would be another great opportunity to pick up a smaller TS as well.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
16274 posts in 4181 days
#8 posted 02-20-2010 03:15 AM
I agree with the cheap table saw solution. I got by with the Ryobi (around $119) for several years, and I was doing a lot more varied cuts than you plan to do. You don’t need to use the stand…. you can stick it anywhere and just pull it out when you need it.
View WayneC's profile
WayneC
13753 posts in 4060 days
#9 posted 02-20-2010 03:21 AM
I am in the bandsaw camp. I think it would be more useful for turning.
View KMJohnson's profile
KMJohnson
165 posts in 2984 days
#10 posted 02-20-2010 03:23 AM
Ryobi or Delta saws are good, skil brand wont last you long enough to make shop room for it. They are real bad saws. Boss baught 2 new ones and they didnt last us one job before they burnt up.
-- Let's do it in the wood pile!
View GMman's profile
GMman
3902 posts in 3660 days
#11 posted 02-20-2010 03:38 AM
Maybe good for you KM is in construction and sometime they are rough on tools.
View Glen Peterson's profile
Glen Peterson
556 posts in 3019 days
#12 posted 02-20-2010 04:07 AM
I vote for the bandsaw. Many turners just own lathes and bandsaws. My biggest objection to the small table saw is it’s ability to rip 3” thick stock. I’m not sure of the motor’s hp, but 3” thick could really strain a smalll motor. You also might not be able to rip stock that thick in one pass on the table saw. You may have to flip it end-for-end and make a pass on the opposite side. If you don’t have either a bandsaw or table saw at this point, I think a band saw is a better first choice for a turner because you can more easily cut logs into turning blanks for bowls, etc and easily cut blocks of wood into circles for turning blanks. In either case, I recommend shopping on the used market. You could probably buy a used band AND a used table saw for $179. Good luck.
-- Glen
Jonathan
#13 posted 02-20-2010 04:19 AM
Guess I didn’t see the 3-inch stock part… read right past that! The bandsaw might be a better fit for that. Are you going to be adventuring into other things, or just focusing on turning for now? Maybe the bandsaw is a better fit then.
View araldite's profile
araldite
188 posts in 3367 days
#14 posted 02-20-2010 04:39 AM
For turning, the quality of the cuts is not important. For your purpose, Skil saw is probably OK. Otherwise, I would not recommend Skil. It’s poor quality in my opinion.
The question is, how thick of a material will you ever want to cut? Any table saw is limited by thickness. If you’re really only ever wanting to be cutting 2” thick, and occasionally 3”, and willing to flip the board, this saw is probably OK. But you’re just about maxed out. If you think you might some day ever want to go thicker, look at a cheap bandsaw. That’ll let you cut blanks up to at least 6”.
Most people recommend buying beyond what you think you need today because most of us have experienced what you’re experiencing and wound up moving up to bigger tools once we’ve moved up in our abilities. I do wood turning and the only saw I use for that is the band saw and, even though I have a big table saw, the band saw is really the best match for a wood turner.
-- Failure is the road to success if you learn to learn from your mistakes - Vince, Greenville, SC
View 8iowa's profile
8iowa
1580 posts in 3724 days
#15 posted 02-20-2010 05:49 AM
I would pass on the table saw at Lowes. In my opinion, a universal type electric motor is a poor choice of power for a table saw. I’ve seen these saws at Lowes, and frankly, they don’t even look safe to me.
Look for a used Shopsmith model 500 (ocupies 12 sq ft) or a used table saw powered by an AC induction motor. $300 or thereabouts would probably do the job for either choice.
