DW735 Drive Roller Replacement
Forum topic by greatview posted 02-23-2016 07:57 PM 1580 views 0 times favorited 5 replies Add to Favorites Watch
View greatview's profile
greatview
133 posts in 3395 days
02-23-2016 07:57 PM
Topic tags/keywords: question 735 drivr rollers
Has anybody done this? If so, how much of a job is it ? And where’s the best place to purchase. I’m seeing slippage and have cleaned the rollers but they are several years old and it is probably time to replace them.
-- Tom, New London, NH
5 replies so far
View AlaskaGuy's profile
AlaskaGuy
4990 posts in 2546 days
#1 posted 02-23-2016 09:37 PM
Deleted
greatview
#2 posted 02-23-2016 09:39 PM
Slippage is my problem. Boards frequently do not feed properly.
View MrUnix's profile
MrUnix
7106 posts in 2436 days
#3 posted 02-23-2016 09:52 PM
While I’ve never seen the rollers on that Dewalt, usually slippage can be cured by a good waxing of the planer bed… and/or adjusting the feed roller pressure if the machine has that adjustment (which I don’t think the DW735 has). I have a hard time believing that enough material has been worn off to significantly reduce the roller diameter… but I guess it’s possible with enough use and time. Based on the parts diagram, they are just spring loaded and held in place by a bracket across the bottom of each bearing block (two screws each) – which is an identical setup to many machines… even my Makita. I would think it should be fairly straightforward.
View WhyMe's profile
WhyMe
1080 posts in 1798 days
#4 posted 02-23-2016 10:26 PM
What did you use to clean the rollers?
greatview
#5 posted 02-23-2016 11:05 PM
Alcohol and mineral spirits neither one of which improved things. The rollers are about 8-10 years old and have seen lots of use..
