sharpen jointer blades
Forum topic by deadherring posted 02-22-2016 09:07 PM 859 views 1 time favorited 7 replies Add to Favorites Watch
View deadherring's profile
deadherring
63 posts in 1640 days
02-22-2016 09:07 PM
Hi,
I have the Porter Cable 6” benchtop jointer. I’ve never sharpened the knives and now I am getting uneven cutting on my workpieces—when I make a bunch of passes part of the piece is cut deeper than the rest. I’m going to check to make sure the fence is 90 to the table but I figure it’s time to sharpen the blades.
I’d really like to try to sharpen them in place since I hear it can be a pain to get them setup right again. Anyone have a good (read: not too complicated) method for sharpening in place? Any jig I can buy that makes it easy? I’m a novice so making complicated jigs probably wont work.
I came across this video on youtube: https://www.youtube.com/watch?v=AN9cE5aNCFo it looks like he is using a jig.
Any advice is appreciated.
Thanks,
Nathan
7 replies so far
View conifur's profile
conifur
955 posts in 1148 days
#1 posted 02-22-2016 09:57 PM
I do believe they have to be machined ground. Setting them is fairly easy with a couple magnetic based torpedo levels. I do more edge jointing then flat/face, so I keep moving my fence in and out to get equal wear on my blades.
View Todd's profile
Todd
398 posts in 1673 days
#2 posted 02-22-2016 11:03 PM
I replaced mine on my Grizzly for the first time last month. I set them without a jig just a piece of al bar stock. They are now set better than they came from the factory. You shouldn’t be scared to maintain your machine. An unmaintained machine is unsafe.
+1 conifer. When doing edge jointing I move my fence in order not to wear any one spot on the knives.
-- Todd, Huntsville, AL
View rwe2156's profile
rwe2156
2925 posts in 1477 days
#3 posted 02-22-2016 11:08 PM
You’re better off just buying new blades when you compare the cost of resharpening.
Don’t try to do them yourself.
Resetting the blades is not that difficult follow the manufacturer’s instructions.
A magnetic jig is very hand.
View mahdee's profile
mahdee
3883 posts in 1764 days
#4 posted 02-23-2016 12:05 AM
I have a very simple jig to sharpen mine. If you want, PM me and I’ll send you some pictures of it. It is basically a 2×4 with two 45 degrees angel cuts on each sides. I put the blades in and use a diamond sharpener on top.
-- earthartandfoods.com
View pintodeluxe's profile
pintodeluxe
5657 posts in 2809 days
#5 posted 02-23-2016 12:09 AM
Just replace them. New blades are often less than the resharpening fee.
I used a Snapcheck digtal gauge last time I replaced mine. It kept everything within .002” of the outfeed table. It is a pain though. I think when they are dull again I will get the Shelix head.
conifur
#6 posted 02-23-2016 12:29 AM
@ rwe2156 >You’re better off just buying new blades when you compare the cost of resharpening.
I dont know where you live, here in WI they charge .10-.15 and inch so for a 3 blade 6” jointer at .15 an inch, thats just less then 10$, thats what I pay.
deadherring
#7 posted 02-24-2016 08:08 PM
Thanks for the advice. It sounds like replacing the blades is the way to go. I found these on Amazon the match the model I have:
http://www.amazon.com/POWERTEC-148015-6-Inch-Jointer-PC160JT/dp/B005NYXS5W/ref=pd_sim_sbs_201_1?ie=UTF8&dpID=41i4bLoqWWL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=1XH2HWJY6MW3ZAZ279DK
They don’t look like they are awesome quality so if anyone has other suggestions? Also some folks made reference to a snapcheck digital gauge—any advice on how to get them installed? The Porter Cable manual has no instructions at all on how to remove and replace.
Thanks,
Nathan
