Sealing Jatoba
Forum topic by Don posted 02-21-2016 05:23 PM 738 views 0 times favorited 6 replies Add to Favorites Watch
View Don's profile
Don
551 posts in 3116 days
02-21-2016 05:23 PM
Hi folks, I made some amp isolation boards from Jatoba for a client. He intends on using a wax (Briwax) for finishing and will do it himself. All he wants me to do for finishing is to apply a sanding sealer to close all the pores, I would assume.
I thought I had a can of Sanding Sealer on hand but it turned out to be Wood Conditioner.
So…..question:
Can I use the conditioner in place of the sealer or, barring that, can I use something else in place of the sealer?
Cheers…Don
-- -- Don in Ottawa, http://www.donebydon.ca
View MadMark's profile
MadMark
979 posts in 1327 days
#1 posted 02-21-2016 05:29 PM
Jatoba isn’t open pored so sealant isn’t really needed. I use 50%-50% poly / mineral spirits as a penitrating wash.
It’ll turn burgundy in short order even if it’s orangish off the saw.
M
View Don's profile
Don
#2 posted 02-21-2016 09:47 PM
What about a Danish Oil and wax finish?
MadMark
#3 posted 02-21-2016 10:03 PM
Depends on how much seal you want. Meself I prefer some poly for less humidity changes. Oil and wax degrade faster than a good coat of poly. How long is this expected to last and how often do you want to renew the finish?
M
View Don's profile
Don
#4 posted 02-21-2016 10:08 PM
There are 6 platforms and once in place, they won’t be moved, just have audio equipment sitting on the,. The client declined a Poly finish for fear of scratching and trying to refinish the scratch. He suggested the sanding sealer and wax (Briwax) but I questioned the use/need for the sealer.
Finish is now wide open to me which is why I thought of the Danish Oil and wax finish.
MadMark
#5 posted 02-21-2016 10:58 PM
Matte finish poly cut 50-50 w/mineral spirits will give a protective finish for humidity stablization but not thick enough to notice. Scratches won’t show and jatoba is naturally scratch resistant. Try it on a piece of scrap & then decide.
M
View gfadvm's profile
gfadvm
14940 posts in 2564 days
#6 posted 02-22-2016 01:07 AM
I have finished Jatoba with BLO and wax and if you’re going for minimal shine, it works. Easy to redo if scratched (but Jatoba is hard to scratch!)
