Help with Bosch Colt router arbor lock
Forum topic by 559dustdesigns posted 02-18-2010 01:35 AM 1535 views 0 times favorited 3 replies Add to Favorites Watch
View 559dustdesigns's profile
559dustdesigns
633 posts in 3071 days
02-18-2010 01:35 AM
Topic tags/keywords: question bosch trim router arbor lock button repair router traditional
Does anyone have a Bosch Colt trim router with arbor lock button problems? I have had this router for about 3 or 4 years, it’s been a great tool. I recently have experienced difficulty using the red arbor lock button used to change bits. The button is hard to press and seams to be to short to engage the arbor shaft. I have been forced to remove the routers base and use two wrenches to loosen the collet. Has anyone had this problem or a solution to fix it?
-- Aaron - central California "If you haven't got the time to do it right, when will you find the time to do it over?"
3 replies so far
View Sean's profile
Sean
156 posts in 3518 days
#1 posted 02-18-2010 01:40 AM
If I remember correctly, everytime this tool was reviewed they mentioned the very problem you are talking about….just a design flaw. not aware of any solution.
-- "Democracy is by far the worst system of government. Except all the others that have been tried." ~ Winston Churchill
View MarkwithaK's profile
MarkwithaK
370 posts in 3081 days
#2 posted 02-18-2010 03:12 AM
I bought one not long ago and it came with 2 wrenches, never used the arbor lock button.
-- If at first you don't succeed then maybe skydiving isn't for you.
View shopdog's profile
shopdog
577 posts in 3389 days
#3 posted 02-18-2010 04:14 AM
I have that problem with mine. I use 2 wrenches.
-- Steve-- http://www.urbanexteriors.biz
