Does anyone have a laser cutter?
Forum topic by Mark Edmondson posted 1191 days ago 708 views 0 times favorited 6 replies Add to Favorites Watch
View Mark Edmondson's profile
Mark Edmondson
38 posts in 1374 days
1191 days ago
Topic tags/keywords: laser cutter
I have some parts I’d like to cut out of 1/2” (15/32) plywood, and need a laser cutter to do it. Does anyone out there have one? I have everything prepared on CAD files with max dimensions of 20”x26”.
Thanks!
-- I have been impressed with the urgency of doing. Knowing is not enough; we must apply. Being willing is not enough; we must do. — Leonardo Da Vinci
View JAGWAH's profile
JAGWAH
924 posts in 1255 days
#1 posted 1191 days ago
I’ll post just to pop this to the top of the list. I’d be interested in anyone as well.
Maybe Luke or Obywan has a abre that will worm out there.
-- ~Just A Guy With A Hammer~
View nerdkraft's profile
nerdkraft
34 posts in 1189 days
#2 posted 1189 days ago
1/2” is too thick for most laser cutters – even if you found someone with a really powerful laser cutter, at that depth you would end up with a major kerfing issue.
I would suggest CNC router like a shopbot. You can check on 100kgarages.com or pm me if you are need someone.
View 459fitter's profile
459fitter
30 posts in 1236 days
#3 posted 1187 days ago
You might have better luck finding a machine shop with a water jet. I beleive that they will cut just about anything and very accurate.
-- Andy ---- Missoula, MT
View TheKackler's profile
TheKackler
2 posts in 545 days
#4 posted 545 days ago
I have a laser cutter and can cut up to 1/4 inch.
https://www.facebook.com/media/set/?set=a.2416302605460.135732.1188196704&type=3
I am happy to do some custom cuts!
View crank49's profile
crank49
2290 posts in 1142 days
#5 posted 545 days ago
Wouldn’t a laser burn the wood at that thickness.
My company has a water jet cutter. It can cut anything up to 7” thick granite and maintain plus/minus .002” tolerance. Costs about $85/hr to run it though.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
TheKackler
2 posts in 545 days
#6 posted 545 days ago
The laser burns the wood when trying to cut with a few passes.
Also depends on type of wood.
I haven’t tried cutting low power with multiple passes… it would take a long time but may be worth it!
