Nova Midi won't close question!
« back to Woodturning forum
Forum topic by Roadhouse posted 02-20-2016 08:48 AM 794 views 0 times favorited 6 replies Add to Favorites Watch
View Roadhouse's profile
2 posts in 758 days
02-20-2016 08:48 AM
Topic tags/keywords: lathe
I have a Harbor Freight lathe and a Nova Midi 4 jaw chuck. When I put the chuck on and try to tighten it down to hold my worm screw that came with it, the jaw guides hit the end of my spindle and won’t close all the way. Is there a spacer I need to bring the chuck out farther on the spindle?
View LeeMills's profile
513 posts in 1232 days
#1 posted 02-20-2016 08:27 PM
I have heard of that before (not necessarily with a Nova or HF).
You may have problems with other brands of face plates and other devices also. I assume the HF spindle is just a little longer than standard.
A thick washer from a hardware store may work in a pinch but it will not be ground flat and may induce some runout.
In an early (1980’s) Del Stubbs video he had to do the same with a screw chuck.
I’m not a fan of the “anti-lock” washers but they are at least flat to start with but may deform over time from use.
View Wildwood's profile
2267 posts in 2066 days
#2 posted 02-20-2016 10:45 PM
You have to close the jaws so tightens in that slot of the wood worm screw. Instructions for that chuck say same thing on how to install woodworm screw. If that is not happening don’t know what to tell you. My Oneway chuck works the same way.
-- Bill
2 posts in 758 days
#3 posted 02-21-2016 12:46 AM
Thanks for the info guys. I’ll have to play around with some spacers and/or mounting the worm wood screw first.
View caine's profile
2 posts in 1943 days
#4 posted 02-21-2016 03:40 PM
make a wooden washer out of 1/4’’ plywood i had the same problem .the spindle on the harbor freight lathe is longer than the spindle on my jet 1220 lathe.
View xmastree's profile
47 posts in 911 days
#5 posted 02-21-2016 03:53 PM
How much of the HF spindle’s excess length would you estimate you’d have to machine off for the Chuck jaws to clear?
To measure, close the jaws and install the Chuck on the spindle. When it stops threading on, simply measure the gap between the spindle’s shoulder and the chuck’s mating surface.
If you’re only talking about a millimeter or two, that could be machined off easily, and then the spindle would be standard and you wouldn’t have to worry about spacers and runout.
-- Every tree is a Chistmas tree with its gifts hidden inside.
#6 posted 02-21-2016 06:34 PM
Hmmm.. I’ve checked online and I see the the HF spindle might not lend itself to the method I mentioned above, though mine does.
I would imagine some manufacturer would offer machined spacers for this kind of issue.(?)
