Cutting splines on a table saw
Forum topic by 716 posted 02-19-2016 06:24 PM 1104 views 0 times favorited 30 replies Add to Favorites Watch
View 716's profile
716
502 posts in 915 days
02-19-2016 06:24 PM
I want to edge glue up 7” long hard maple boards. For that I plan to cut slots along the whole length of the boards and insert splines. I plan to use a single end blade from my 8” dado stack, as my thin kerf blades are too thin for this task.
In order for the spline to not show up I plan to slowly lower the board on the blade from above, about 5” from the end and stop the saw when the cut is 5” from the other end. As the boards are not perfectly straight I will use two featherboards before and after the blade.
Do you see safety problems with this setup ?
-- It's nice!
30 replies so far
View joek30296's profile
joek30296
53 posts in 2865 days
#1 posted 02-19-2016 06:36 PM
I assume you’re talking about 7 ft. boards and not 7 inch since you’re leaving 5 inches at each end. I’ve done that a number of times successfully. The only problem I see with using one side of your dado blade is many sets have left and right blades and teeth point either left or right. You might be able to use your thin kerf blade by making the first cut, then turn the stock end for end and cut again. Set up on a practice piece first to get the right width slot.
-- "There are two theories to arguing with a woman....neither of them work"
View 716's profile
716
#2 posted 02-19-2016 06:53 PM
So what can happen when cutting with the only lets say right teeth ? Will it try to pull the board to the side ?
I am not sure that two pass method will give me acceptable slot consistency especially if the boards are of slight different thickness.
-- It's nice!
View shampeon's profile
shampeon
1775 posts in 2182 days
#3 posted 02-19-2016 06:57 PM
Why are you adding splines? A glue joint will be stronger than the wood. If you’re concerned about alignment, use some cauls and clamps.
You’re really going to need to dimension the boards correctly before glue up.
And let’s just put me down as “concerned” about the idea of slowly lowering a thin board onto a spinning saw blade by hand.
shampeon
#4 posted 02-19-2016 06:58 PM
Also, please don’t put a feather board on the outfeed side of a blade. You’re really flirting with dangerous kickback.
View 716's profile
716
#5 posted 02-19-2016 07:08 PM
Also, please don t put a feather board on the outfeed side of a blade. You re really flirting with dangerous kickback.
- shampeon
Why ? The cut is not through so it is not going to pinch the blade.
-- It's nice!
View 716's profile
716
#6 posted 02-19-2016 07:12 PM
Why are you adding splines? A glue joint will be stronger than the wood. If you re concerned about alignment, use some cauls and clamps.
You re really going to need to dimension the boards correctly before glue up.
And let s just put me down as “concerned” about the idea of slowly lowering a thin board onto a spinning saw blade by hand.
- shampeon
It is a lot of clamps that I do not have, the same goes to thicknesser.
Do you think lowering the blade below the table surface and then rising it when the board is set up would be a better approach than lowering the stock onto the blade ?
-- It's nice!
shampeon
#7 posted 02-19-2016 07:13 PM
Putting pressure on the board before and after the blade will push the board against the side of the blade while it’s spinning, causing kickback.
But it’s your nuts, man.
shampeon
#8 posted 02-19-2016 07:22 PM
If you’re going to do woodworking, you’re going to need clamps and a way of dimensioning your stock. Cheap f-style bar clamps will work fine for this. A hand plane and some 2×4s will get you some cauls.
I do not recommend raising your blade into your boards, and really don’t think cutting slots for splines is a real solution. This whole operation just sounds dangerous and unnecessary. Get the boards prepped first before even considering gluing them up.
View bondogaposis's profile
bondogaposis
4727 posts in 2350 days
#9 posted 02-19-2016 07:43 PM
Yes, it could very well push on that thinner wood into the blade after the cut. It depends partly on how deep the cut is, the deeper it is the more likely that the feather board might cause the blade to catch. You could still use the feather board but put no tension on the rear one. I personally would prefer to cut stopped splines on a router table w/ a slot cutter.
-- Bondo Gaposis
View 716's profile
716
#10 posted 02-19-2016 07:46 PM
Putting pressure on the board before and after the blade will push the board against the side of the blade while it s spinning, causing kickback.
- shampeon
There is the fence the board is pushed into not the blade. No ?
-- It's nice!
View jbay's profile
jbay
2288 posts in 898 days
#11 posted 02-19-2016 07:48 PM
I would do it all day long as long as you have the experience. I wouldn’t use 2 feather boards. If it were me I would use 1 long board.
View Ger21's profile
Ger21
1074 posts in 3129 days
#12 posted 02-19-2016 07:49 PM
After passing the first featherboard, the release of pressure can cause the board to move a little bit into the blade, possibly causing kickback.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View 716's profile
716
#13 posted 02-19-2016 08:00 PM
- Ger21
Huh ? Are you saying that featherboards are inherently dangerous and should not be used ?
-- It's nice!
View hotbyte's profile
hotbyte
991 posts in 2974 days
#14 posted 02-19-2016 08:13 PM
This….you can buy 3/4” pipe clamps and some 3/4” black pipe fairly cheap.
If you re going to do woodworking, you re going to need clamps and a way of dimensioning your stock. Cheap f-style bar clamps will work fine for this. A hand plane and some 2×4s will get you some cauls.
I do not recommend raising your blade into your boards, and really don t think cutting slots for splines is a real solution. This whole operation just sounds dangerous and unnecessary. Get the boards prepped first before even considering gluing them up.
- shampeon
View GregD's profile
GregD
788 posts in 3135 days
#15 posted 02-19-2016 08:37 PM
This cut could also be made using a router with a wing cutter.
But it is completely unnecessary to use splines for a panel glue-up like this. When I was new to woodworking I would do something similar, but it was a lot of work and if anything made the glue-up more difficult. While one might think the spline will perfectly align the boards, it often doesn’t. And it certainly does not reduce the need for clamps – if anything you may need even more pressure to close the joint tight.
Like most things in woodworking, glue-up requires appropriate tools and skills. Your results will get much better after you’ve done it a few times. The first attempt or two are likely to be very stressful and disappointing. Consider cutting a few strips of scrap plywood and practice gluing them up. It will be very educational – well worth the time and cost of the wood.
-- Greg D.
showing 1 through 15 of 30 replies
