How can I get the flattest white surface?
Forum topic by king_nickizzle posted 02-19-2016 02:19 PM 848 views 0 times favorited 10 replies Add to Favorites Watch
View king_nickizzle's profile
25 posts in 843 days
02-19-2016 02:19 PM
Topic tags/keywords: wood white flat mid century modern furniture question
I recently built a small filing cabinet, and painted it white. I chose to build with pine since it’s cheap and would be painted anyway. Unfortunately I can see accents of the wood grain through the paint. It almost looks like imitation wood siding.
I’m now building some more furniture that i need white, and want to see if there is a better alternative. MDF is pretty flat but I’m not sure how sturdy it is. Vinyl is probably another option but may seem kind of cheap. I suppose a planer might work, but I don’t have access to one so wonder if there’s a better alternative. I’m building in the mid century modern style so “flat” is a huge part of the design:
Example 2
10 replies so far
16273 posts in 4150 days
#1 posted 02-19-2016 02:29 PM
I would expect MDF would be the easiest solution, although I share your concerns about strength.
The only way you are going to get the finish you want with pine (or most any other wood) is to build up a surface with grain a filler that can then be sanded back to dead smooth. It’s basically the same preparation method you would use if you were trying to create a mirror-smooth clear finish.
Another thought: If you have access to maple at a reasonable price, you might want to give that a try. I think you would find the grain much less noticeable than pine.
View Alster's profile
100 posts in 3146 days
#2 posted 02-19-2016 02:34 PM
Home center poplar is smooth, flat, relatively inexpensive, and it takes paint very well. It has small pores that require little filling. Paint a coat; sand thoroughly—the paint fills the pores. Give it a second coat; you’ll be good to go.
Much sturdier than plywood or mdf.
#3 posted 02-19-2016 02:37 PM
Good point… I forgot about poplar.
View mrg's profile
815 posts in 2931 days
#4 posted 02-19-2016 02:45 PM
Put two coats of good paint on and let cure. The grain is showing do to not enough of a build up of paint. Sand with wet dry sand paper 400-600 grit lightly, will come out super smooth. Doesn’t take much, use a sanding block.
-- mrg
View CB_Cohick's profile
484 posts in 1183 days
#5 posted 02-19-2016 02:50 PM
The borgs around here carry melamine, which is already white.
-- Chris - Would work, but I'm too busy reading about woodwork.
View greatview's profile
131 posts in 3089 days
#6 posted 02-19-2016 03:18 PM
Try MDO. Strong and dead flat surfaces. Waterproof too. Highway signs are made from MDO.
-- Tom, New London, NH
4906 posts in 2425 days
#7 posted 02-19-2016 03:39 PM
MDO, poplar, or maple would all be good choices. The MDO surface may have slight waves in it (it did for me) but try this if you choose solid wood: prime it (maybe 2 coats) with Zinnser BIN primer, the shellac based stuff. Then sand it smooth and paint. The BIN sands out fairly easily, dries quickly so you aren’t waiting, and should give you a nice smooth surface.
View conifur's profile
955 posts in 1083 days
#8 posted 02-19-2016 03:51 PM
If painting wood, get a good stain blocking primer for your first coat, then paint it white.
#9 posted 02-20-2016 04:02 PM
Thanks for all the great advice everyone! I’ve thought about Poplar myself, but figured that could add up quick. But you get what you pay for too, so that’s not so bad. I wasn’t familiar with MDO though, that sounds like a good choice too!
View AlaskaGuy's profile (online now)
3978 posts in 2241 days
#10 posted 02-20-2016 07:06 PM
Even cherry would work. I’ve painted cherry and being a tight grained wood it paints very well.
