| Forum topic by BammBamm | posted 1188 days ago | 2360 views | 1 time favorited | 11 replies | ![]() |
1188 days ago |
Topic tags/keywords: question Hey all, Was hoping someone has worked with Tigerwood in the past, and has some pointers about glue up. I’ve been told to wipe down with solvent or lacquer thinner prior to gluing…but am just curious if that statement is correct, and if there are any other special considerations to consider when gluing? I currently use alot of Titebond II and Titebond III glue…Will these work, or do I need to go to a different glue? Any help would be greatly appreciated. I have not started yet, want to get my ducks in a row before forging ahead. Thanks all! Great place to find answers! -- Nature does not hurry, yet everything is accomplished. --Lao Tzu |
11 replies so far
#1 posted 1188 days ago |
I’ve worked with it a bit and have a project that’s close to completion that I hope to be posting in the next few weeks. I glue it like any other wood using normal titebond. The wood does have a slight oily feel to it so I can see why someone would recomend wiping it down but I have had no trouble with it. If you’re unsure, do a test. Glue up a couple of scraps without any wiping and see how well it holds. -- Don - I wood work if I could. Redmond WA. |
#2 posted 1188 days ago |
When working with Tiger Wood, you have to hit it with a golf club first…then it will be easier to work with. With a name like BammBamm, you should know that. -- Steve-- http://www.urbanexteriors.biz |
#3 posted 1188 days ago |
Ive built 6 or 7 circular stairs out of Tiger Wood over the years, and have learned to err on the side of caution when laminating. For the most part, you can ‘get away’ with wiping down with Lacquer thinner and using yellow glue…but over the course of the first couple of stairs, had run into a couple of minor problems. Changed protocol, and now wipe down with Lacquer thinner, and use epoxy for all laminations. Never had a problem since. -- Come to the dark side....we have cookies... |
#4 posted 1188 days ago |
Didn’t know this. -- Let's do it in the wood pile! |
#5 posted 1188 days ago |
I’ve used tiger wood in cutting boards as a decorative area (and they seem to sell to golfers well) and it glues up just fine. A wipe with acetone wouldn’t hurt but I’ve never had a problem. -- Don't let the perfect be the enemy of the good. |
#6 posted 1188 days ago |
I recently made 2 cutting boards…one with just tiger wood, and the other is tiger wood and ipe. I used TB3 glue and splined all of the joints. I didn’t wipe down the wood first. They seem well glued, but they are new, and haven’t stood the test of time. -- Steve-- http://www.urbanexteriors.biz |
#7 posted 1186 days ago |
Thanks for all the humor and tips… Tony_S….when you switched to Epoxy, which did you use? Thanks again all. -- Nature does not hurry, yet everything is accomplished. --Lao Tzu |
#8 posted 1186 days ago |
Hey Bamm… Tried a few different kinds over the years….West System is the best no question. -- Come to the dark side....we have cookies... |
#9 posted 1186 days ago |
I’ve used tiger wood in cutting boards as a decorative area (and they seem to sell to golfers well) and it glues up just fine. A wipe with acetone wouldn’t hurt but I’ve never had a problem. Ellen, You will probably need to use Cheetah wood now. -- Ohh mann...pancakes and boobies...I'll bet that's what Heaven is like! ♣ ♣ ♣ ♣ |
#10 posted 1185 days ago |
Thanks Tony….will keep that in mind. -- Nature does not hurry, yet everything is accomplished. --Lao Tzu |
#11 posted 1185 days ago |
Whene I was working with some wood I had concernes on I emailed the folks at tightbond and they got back to me fairly quickly. The wood was brazillian Redwood and because of the silica or oil or whatever they recommended a wipe down with acetone and glue with tightbond III. Seemed to work well. Good luck -- Mike, Cantral Oregon |
| Forum | Topics |
Woodworking Skill Share
8788 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1528 |
3544 |
15758 |
Hand Tools
2032 |
Jigs & Fixtures
494 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6153 |
