Best starting point for using a lathe?
« back to Woodturning forum
Forum topic by redesigningwood posted 02-18-2016 06:18 PM 1301 views 1 time favorited 27 replies Add to Favorites Watch
View redesigningwood's profile
redesigningwood
169 posts in 983 days
02-18-2016 06:18 PM
Hello hello,
I picked up a lathe a few weeks ago for a song off craigslist (1960’s craftsman with a 40 inch cutting area and
tools included for about $100) and I have been watching a few videos as to how to cut correctly [something about riding the bevel :)]. I’ve been using builder grade 2×4s glued together because I have them around and I wouldn’t want to destroy anything expensive before figuring out what I am doing.
The problems I have been having are catching wood and ripping chunks of wood out, the entire piece of wood
flying past my head, the lathe loosening up after the tool catches the wood, and all smaller details come out VERY rough.
Other then maybe not starting out learning the lathe by trying to make a baseball bat (seemed simple at the time, haha), anyone have some advice for a new lathe user?
-- Mat
27 replies so far
View lew's profile
lew
12329 posts in 3904 days
#1 posted 02-18-2016 06:41 PM
Sharp tools, a little higher RPM’s than you would normally think and stay away from the skew chisel for a while. There are three folks to follow on YouTube- Carl Jacobson, Brian Havens and Captian Eddy.
redesigningwood
#2 posted 02-18-2016 06:54 PM
Lathe was typically on second to highest setting, only thing I was using was a gauge that i sharpened (hopefully correctly), and yes, the skew chisel and me do not get along right now. The tools that came with the lathe didnt include a wide “roughing gouge” per say, these are the tools that the lathe came with – http://www.ebay.com/itm/Craftsman-Lathe-Turning-Tools-for-Woodworking-9-2855-/301811591534
-- Mat
MrUnix
6949 posts in 2348 days
#3 posted 02-18-2016 07:20 PM
Unless you are knocking the corners off to get it somewhat rounded, you need to go slow and take very, very light cuts until it’s roughed out. I use 2x material a LOT to make faceplates/glue blocks, and if you just throw them on there square, it takes a bit of patience to get them round. I will usually at least make them octogonal on the bandsaw first before turning, which helps a lot. Oh, and I turn most of them just using an old screwdriver sharpened on a belt sander :)
View Kelly's profile
Kelly
2092 posts in 3093 days
#4 posted 02-18-2016 08:05 PM
I’m a newbie to lathes too. I have been able to get my knives sharp using my 1” belt sander and just a touch, until I finish getting the four wheel grinding stations set up for it.
To start, I just use 2×2’s. Generally, about ten inches or less long. It gives me a lot of good practice, both for getting a feel for sharpening and for turning.
I’ve had a lot of minor catches, but nothing that threw anything. For square stock, I start slow or mid point. The more the pieces vibrates, the slower I go.
I tip the gouge to work off the right or left edge with the part cutting supported directly on the rest. I take small cuts and move a lot.
Squaring goes quick enough I don’t bother with the band saw. Too, it’s just more opportunity to get comfortable with what works.
View waho6o9's profile
waho6o9
8438 posts in 2726 days
#5 posted 02-18-2016 08:07 PM
Face mask
View RobS888's profile
RobS888
2494 posts in 1994 days
#6 posted 02-18-2016 09:28 PM
Carbide tipped tools can really help out when you are starting.
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
redesigningwood
#7 posted 02-18-2016 10:05 PM
Face mask
- waho6o9
haha! Yea I learned that one quickly.
-- Mat
View Bmezz's profile
Bmezz
45 posts in 1532 days
#8 posted 02-18-2016 10:27 PM
Not sure where you live but do yourself a big favour and find a woodturners club in your area. At best they will offer a basic course at worst they will have mentors. Either way it will save you time, money and blood. Don’t underestimate how badly you can get hurt with a lathe. Google AAW and they will have a listing of clubs near you. Stay safe.
-- Member Valley Woodturners Ottawa. Member AAW
View Woodknack's profile (online now)
Woodknack
12371 posts in 2529 days
#9 posted 02-19-2016 01:57 AM
Construction lumber will tear out and break off easier than hard woods, so it’s good in that respect for practice. Once you can get a good finishing cut on pine, hard woods will be a breeze. Crank up the speed, keep your tailstock tight checking it often, and take light cuts.
View Gerry1942's profile
Gerry1942
25 posts in 978 days
#10 posted 02-19-2016 03:17 AM
Turning is all about feed and speed. A turning class at the local Woodcraft store is worth the investment, or buy a video I for beginners. One can get hurt if you do not learn lathe safety
redesigningwood
#11 posted 02-19-2016 02:53 PM
- Gerry1942
I have been using youtube as references to turning, hopefully with a little more patience I will figure it out.
-- Mat
View mrg's profile
mrg
828 posts in 3148 days
#12 posted 02-19-2016 03:11 PM
There are a couple of clubs in your area. I looked at your home page and inboxed you. Taking a class or joining one of the clubs and getting mentored is the easiest way of learning. You also learn different ways of executing things and finding what works best for you.
-- mrg
View KYSean's profile
KYSean
119 posts in 3745 days
#13 posted 02-19-2016 04:21 PM
Go to your local AAW woodturning club. Bad habits are harder to break than learning the correct way first.
-- http://editedwrite.com
redesigningwood
#14 posted 02-19-2016 04:44 PM
- KYSean
Not sure where you live but do yourself a big favour and find a woodturners club in your area. At best they will offer a basic course at worst they will have mentors. Either way it will save you time, money and blood. Don t underestimate how badly you can get hurt with a lathe. Google AAW and they will have a listing of clubs near you. Stay safe.
- Bmezz
- mrg
I’m going I’m going!!!!
-- Mat
Kelly
#15 posted 02-19-2016 04:49 PM
Lew, thanks for the tips of Youtube videos. The closest place I could go for lessons requires a two hour trip for each.
_
“There are three folks to follow on YouTube- Carl Jacobson, Brian Havens and Captian Eddy.”
