Resawing on table saw.
Forum topic by 716 posted 02-17-2016 09:38 PM 1139 views 0 times favorited 21 replies Add to Favorites Watch
View 716's profile
716
502 posts in 939 days
02-17-2016 09:38 PM
I am trying to save some wood and make a table top from 20mm plywood and gluing 5mm hard maple veneer on top.
I used up my budged for tools for some foreseeable future and I have to cope with what I have so a bandsaw is out of the question for now.
The question is: should I even attempt to resaw 7ft long 6” wide 4×4 hard maple boards into three 5mm each on 2HP Grizzly hybrid saw with thin kerf rip blade.
Or better to play on the safe side and make the whole table top from solid wood ( which will make a better table anyway).
-- It's nice!
21 replies so far
View shampeon's profile
shampeon
1775 posts in 2205 days
#1 posted 02-17-2016 10:00 PM
The first rule of veneering is to veneer both sides of the piece to prevent cupping, for the same reason that you need to apply finish to both sides of a piece.
For a table top, I don’t think I’d use veneered plywood. If I’ve learned one thing, it’s that the wood costs are (usually) dwarfed by the time and effort put into the pieces. If you’re going to spend a lot of time on something, do it right, and don’t cut corners.
I’d resaw your 4×4 maple into 3 1.2” boards (losing 0.375” from the 1/8” thin-kerf blade). That would leave you a decently thick top for final dimensioning.
View 716's profile
716
#2 posted 02-17-2016 10:05 PM
Sorry 4×4 really wanted to be 4/4. I would never think wasting 4”x4” maple into regular boards.
But you are right.
When one starts cut corners he’d better go and buy some ready furniture in the store. It is cheaper that way.
-- It's nice!
View AandCstyle's profile
AandCstyle
3068 posts in 2279 days
#3 posted 02-17-2016 11:21 PM
716, even if you had a band saw, you would have to be extremely lucky or extremely skillful to get 15mm of usable stock out of a 4/4 board that length. By the time you face joint and plane it, then plane again after the band saw cuts. FWIW
-- Art
View rwe2156's profile
rwe2156
2958 posts in 1503 days
#4 posted 02-18-2016 12:47 PM
My question is how big is the table and how much money are you really saving?
If it were birdseye or quilted maple it would be different.
If you just want to try it yeah you should be able to resaw with a good sharp blade and steady feed.
I would definitely use an auxilary tall fence and a featherboards.
Keep in mind of you stop the cut maple will burn in a heartbeat.
Be ready for warpage and cupping, too.
View bondogaposis's profile
bondogaposis
4755 posts in 2373 days
#5 posted 02-18-2016 01:06 PM
Make the top from solid wood, you will be much happier. Way less effort and better product.
-- Bondo Gaposis
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2392 days
#6 posted 02-18-2016 01:25 PM
I agree with Art, you’d be real lucky to get 3 boards out of your 4/4. If they’re quartersawn, stable, and your setup is dead on, maybe (just maybe).
As far as the money saved, I’ll assume you’re using a high-quality plywood, in which case, the money saved is probably negligible between plywood +maple, and just maple. If you’re not using a high quality plywood, and you get your maple applied, and the season changes, and your maple decides to cup/warp…my guess is that the first thing to fail is going to be that top layer of the plywood pulling away from the underlying layer. Also, I don’t know how wide your top is, but even at 5mm thick, across the width of the tabletop, you’re going to have movement.
Long story short, you’ll save yourself time, frustration, and future issues if you just go solid wood. And, I think you’ll feel better about the finished product.
View waho6o9's profile
waho6o9
8205 posts in 2599 days
#7 posted 02-18-2016 01:44 PM
“Or better to play on the safe side and make the whole table top from solid wood ( which will make a better table anyway).”
Make the better table top 716 !
View ThomasChippendale's profile
ThomasChippendale
244 posts in 954 days
#8 posted 02-18-2016 02:59 PM
I have sucessfully performed what you are intending to do on two surfaces, respectively 21 and 15 inches wide. I used 3/4 inch maple plywood as a substrate and with a good bandsaw, sliced 1/4 + inch, 6 inch wide planks from 8/4 Padauk in one case and 8 inch wide 4/4 mahogany in the other.
I jointed the edges and laminated/edge glued it to the plywood using a combination of clamps across the surface and heavy weights pressing down. I used Ă©poxy as a glue so I had plenty of working time. Then I passed them in the planer to a final thickness of 1 inch. There is a chance for further cuping I agree but the cross members, in your case the apron, will contain the cupping until you apply finish on both side.
The main reason for this was to get the nicely figured wood to be displayed, it has held-up well.
-- PJ
View AlaskaGuy's profile (online now)
AlaskaGuy
4201 posts in 2331 days
#9 posted 02-18-2016 08:00 PM
If you don’t have the proper tools go buy veneer for some one who does. It’s a no brainier 716. There’s about a million place to buy veneer.
rwe2156
#10 posted 02-19-2016 12:38 PM
Alaska Guy:
I’ve looked for thicker veneer for a table top not easy to find.
Do you have any sources?
View Ger21's profile
Ger21
1074 posts in 3153 days
#11 posted 02-19-2016 03:10 PM
As previously mentioned, you always need to veneer both sides, or it will warp badly.
Also, if gluing a thick veneer to plywood, it should be no thicker than 1/8”, or 3mm. Any thicker and you may have issues with it splitting when it wants to expand and contract.
Certainly Wood sells 1/16” veneer in a variety of species.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
BinghamtonEd
#12 posted 02-19-2016 03:52 PM
Is there a reason you need it very thick? What sort of finish are you planning on using?
View Kelly's profile
Kelly
2039 posts in 2966 days
#13 posted 02-19-2016 06:06 PM
As to the arguments against using a veneer, I disagree. It doesn’t take many years of being in the wood working world before you notice an awful lot of high quality product has been made using veneers. Much of it is museum quality.
The biggest change I see in veneer use would be the thicknesses. In days of old, you could scrape and even sand many of the veneered items. Now, just looking at the stuff will blow through it. Of course, if you’re making your own, it could be up to an eight of an inch thick.
ThomasChippendale
#14 posted 02-19-2016 09:10 PM
Even 1/4 inch !
-- PJ
View 716's profile
716
#15 posted 02-19-2016 11:19 PM
People above ( not me ) say that your piece will wrap into a tube and crack into splinters.
-- It's nice!
