croccust sled base
Forum topic by John S posted 02-17-2016 02:35 PM 623 views 0 times favorited 2 replies Add to Favorites Watch
View John S's profile
John S
20 posts in 2272 days
02-17-2016 02:35 PM
Topic tags/keywords: jig tablesaw crosscut sled base material miter sled mdf plywood hardboard question
I want to build a crosscut sled for my table saw. I just added the Delta T3 rip fence to my 43 year old Craftsman 10 inch saw, yes I bought it new in 1973. Now I looking to improve things even more now that I am retired and have a more time for my shop.
My question is about the sled base. What is the consensus on the material to use? I have seen plywood, MDF hardboard and tempered hardboard. I have seen 1/4, 1/2 and 3/4. I like the thinner material because it gives more depth of cut but need your opinions and experiences.
Thanks for the input
2 replies so far
View HokieKen's profile
HokieKen
4595 posts in 1015 days
#1 posted 02-17-2016 02:55 PM
Any of the materials you mention will work. Thickness depends on the material and the size of the sled. Keeping as much cut depth is nice, but rigidity is necessary to get consistent results. My sled is 1/2” MDF with Formica laminated on both sides and 1/8” hardboard topper to allow me to adjust for zero clearance with different blades and bevel angles. Just make sure you select a stable material (MDF or Baltic Birch Ply are my preferences) and make sure it’s thick enough that it won’t flex (1/2 works great for me, 1/4 would be way too thin IMHO) and you’ll be in good shape.
-- Kenny, SW VA, Go Hokies!!!
View rubber_ducky's profile
rubber_ducky
36 posts in 755 days
#2 posted 02-17-2016 02:56 PM
I think that the thickness will depend on whether or not you’re planning on adding t-tracks to your base. If not, 1/2” is sufficient. The type of material depends on what you’re comfortable with. I don’t like all of the [nasty] dust from MDF, so I use BB ply. Laminated particleboard is another option.
