Unisaw wiring diagram dual voltage motor
Forum topic by Fourthgencarp posted 02-17-2016 02:25 PM 2499 views 0 times favorited 14 replies Add to Favorites Watch
View Fourthgencarp's profile
Fourthgencarp
8 posts in 859 days
02-17-2016 02:25 PM
Topic tags/keywords: unisaw
I have a unisaw 34-761 with a dual voltage motor when I got the saw it was wired for 220 I’m trying to wire it for 110 and the Rockwell 83-621 motor has no wire diagram on it I have another unisaw 34-461 with a leeson dual voltage I went off the diagram on that motor and the motor won’t start it just hums. Does anyone have a diagram for that motor or a reason it won’t start?
14 replies so far
Fourthgencarp
8 posts in 859 days
#1 posted 02-17-2016 02:50 PM
Also the motor was rewired at one time so it has 4 black wires numbered 1 2 3 4. And 2 red wires with no numbers
View MrUnix's profile
MrUnix
6770 posts in 2228 days
#2 posted 02-17-2016 05:28 PM
According to Leeson, it’s either a model 120925 or 120997 (1.5HP). You can look up the wiring diagram at their web site by searching for the model number. Alternatively, you could probably send them an e-mail or give them a call and they would tell you what you need to do. Oh, as for not starting… if it’s wired correctly, I’d check the start capacitor – you can test it with a cheap multimeter in resistance mode.
Fourthgencarp
8 posts in 859 days
#3 posted 02-17-2016 06:29 PM
The leeson is wired for 110. But I’m trying to wire the Rockwell motor for 110
MrUnix
#4 posted 02-17-2016 06:32 PM
The leeson is wired for 110. But I m trying to wire the Rockwell motor for 110
- Fourthgencarp
You said it was a Rockwell 83-621 motor, right? Rockwell doesn’t make motors, and that motor model number comes back as being made by Leeson (See this page). What does the motor data plate say?
Fourthgencarp
8 posts in 859 days
#5 posted 02-17-2016 07:56 PM
View shastaman's profile
shastaman
30 posts in 878 days
#6 posted 02-17-2016 09:06 PM
From the above link…
(Lesson) 120997 replace Delta UNISAW® motor 83-621 (1.5HP
runswithscissors
2768 posts in 2054 days
#7 posted 02-17-2016 10:22 PM
I see that motor pulls 19.2 amps at 110 volts. Wondering whether a 20 amp circuit will be marginal for that motor. Might be cheaper/easier to put in a 220 v. circuit.
Fourthgencarp
8 posts in 859 days
#8 posted 02-17-2016 11:22 PM
I’m converting the saw cause I just built a barn and there’s no service yet gotta wait till spring so it’s running off an extension cord
runswithscissors
#9 posted 02-18-2016 03:00 AM
Okay, that raises another concern. You will get voltage drop with an extension cord, especially with a long one. I’d want no less than a 10 gauge extension cord for that use.
Maybe others who no more about this than I do can weigh in.
And, by the way, it’s also possible to use a 220 v. extension cord. I run a piece of outdoor equipment with a 3 hp Dayton motor with an extension cord about 25 feet long. Works fine, and I think it would be better for your motor to not starve it of voltage. I do make a point of not running it when everything is wet (I only use it outdoors, not under shelter).
Fourthgencarp
8 posts in 859 days
#10 posted 02-19-2016 08:08 PM
Either way I still need a wire diagram to wire it 220 or 110. If someone has one of these motors please snap a picture of the diagram
MrUnix
#11 posted 02-20-2016 04:28 PM
Well, it’s not mine, but while scanning through the local CL ads I ran across this Unisaw with the same motor… and this picture was posted for it:
It’s not the best, but might give you a hint or two. You can probably load it into a graphics program and enhance the wiring diagram a bit… maybe.
Also, this data plate was found with a quick google search, which might be a bit better:
PS: Trying to run a 19.2FLA motor on 120v using an extension cord might not be the best idea in the world. I hope you have a sufficient dedicated circuit for it and a really large gauge extension cord!
View bigblockyeti's profile
bigblockyeti
5140 posts in 1749 days
#12 posted 02-20-2016 06:14 PM
- MrUnix
Dedicated circuit, heck I hope he has good insurance and a pretty dim adjuster.
Fourthgencarp
8 posts in 859 days
#13 posted 02-27-2016 02:50 AM
Finally figured out the wiring got it at 110. Runs perfect on a 100’ foot cord doesn’t even dim the lights when I turn it on. The Rockwell motor starts smoother than leeson motor I was surprised
MrUnix
#14 posted 02-27-2016 03:00 AM
You might consider posting how you wired it so anyone else in the same position can be helped in the future.
