Tail Vice
Forum topic by Novice1231 posted 02-15-2010 08:12 PM 1389 views 0 times favorited 5 replies Add to Favorites Watch
View Novice1231's profile
Novice1231
5 posts in 3229 days
02-15-2010 08:12 PM
Hi Y’all. I’m totally new to woodworking. Haven’t even done a project yet! I hope for my first project to be a work bench. I keep running accross the term “tail vice”. Can someone tell me what exactly that is. I can’t find a decent answer on-line. Also, do I need this on my work bench? The only vice I am familiar with is the standard screw the base to the bench top.
5 replies so far
View FredG's profile
FredG
139 posts in 3896 days
#1 posted 02-15-2010 08:25 PM
Try tail vise.
-- Fred
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3314 days
#2 posted 02-15-2010 08:50 PM
try to look at some of the benches in projectsektion
there you will see tail/front/shuoldervises and a cople more that I donĀ“t remmember the name of
the tailvice is at the end of the bench and the front vice is nomaly lokated to your leftside
if you stand in front of the bench and looking at it the shuoldervise is also lokated at the leftside
but is going aut from the other end in a L-shaped form were the vice is atatsh to the short end of the L
hope you get my point and that it helped you
Dennis
Dennisgrosen
#3 posted 02-15-2010 10:49 PM
notottoman
remmember I still smile
I stick with my way of spelling
becourse of this
http://lumberjocks.com/topics/14464
and something on few other blogs (not to bring it up again)
Dennisgrosen
#4 posted 02-15-2010 11:33 PM
here is a bench with a tail vice
http://lumberjocks.com/projects/28062
View Glen Peterson's profile
Glen Peterson
556 posts in 3255 days
#5 posted 02-16-2010 12:47 AM
Hi,
A tail vice is a vice or bench screw on the end of a bench that allows us to use bench dogs. A vice on the side of a bench is typically called a front vice. I posted a bench project this morning that uses a tail vice screw. You can see it and the bench dogs in some of the photos. http://lumberjocks.com/projects/28152
-- Glen
