which band saw for resawing
Forum topic by bradnelson posted 02-17-2016 03:28 AM 715 views 0 times favorited 5 replies Add to Favorites Watch
View bradnelson's profile
bradnelson
53 posts in 2387 days
02-17-2016 03:28 AM
I’m in the market for a new bandsaw which I will use probably 90% of the time for resawing. My budget is $1500 to 1800 maybe 2000. I’ve been looking at the laguna lt14-14suv with 3 hp motor or any of the 7 grizzly band saws in that price range. What about jet or powermatic?
5 replies so far
View Kelly's profile
Kelly
2189 posts in 3186 days
#1 posted 02-17-2016 03:42 AM
Spend time reading reviews, here, on Amazon and so forth. When I did, I learned a lot about the critical “I hates” people discovered only after owning their saw. For example, a common complaint was how hard it was to make adjustments or to change blades.
If all you’re going to do is re-saw, changing blades isn’t as big a deal. But if you are going to switch blades. . . .
Kelly
#2 posted 02-17-2016 04:11 AM
View TheWoodRaccoon's profile
TheWoodRaccoon
364 posts in 1171 days
#3 posted 02-17-2016 05:13 AM
If your’e going to use it for re-sawing 90% of the time, i would go with a 17” or 18” bandsaw, maybe even bigger. The Powermatic PM1500 gets a lot of good reviews. Grizzly also makes nice bandsaws in that size, and may save you some money.
-- still trying to think of a clever signature......
View MrUnix's profile
MrUnix
7115 posts in 2440 days
#4 posted 02-17-2016 05:14 AM
http://www.tannewitz.com/
Might be a bit out of your price range though :(
View ColonelTravis's profile
ColonelTravis
1958 posts in 2135 days
#5 posted 02-17-2016 05:42 AM
I’ve got a Grizzly G0513X2 (under your price range) but for what you get for the money you can’t beat them. Powermatic, Rikon and Jet couldn’t top Grizzly for me, it’s a quality saw. Other than the HP, the specs on mine are not that far off from the 14 SUV. When I first thought about Laguna and saw their prices and then their CS thing scared me off, I dropped them. I’ve read they’ve improved. I don’t know. I didn’t want to risk that much money on it. I think you’re going to get 2” higher resaw with the 14 SUV than any of the 19” Grizzly saws.
Otherwise, usual general advice applies: get the most you can afford.
