Surfacing Zebra Wood
Forum topic by Jim Ganley posted 02-15-2010 01:12 AM 2814 views 0 times favorited 8 replies Add to Favorites Watch
View Jim Ganley's profile
Jim Ganley
49 posts in 3166 days
02-15-2010 01:12 AM
This is one of a mystery’s that I cannot solve on my own, every time I try and run the wood thru the planer it just tears off does not matter whether I take a big bite or just tick it.
-- Jim - Cushing, WI
8 replies so far
View bobkberg's profile
bobkberg
439 posts in 3071 days
#1 posted 02-16-2010 08:24 AM
Never having worked with zebra wood, I can only guess, but here goes…
- Are the planer blades new and sharp?
- Have you tried reversing the direction that the wood goes through the planer?
- Is the cutter head locked in position?
If that doesn’t help, it might be worth it to have a cabinet shop run it through their sheet sander.
-- Bob www.singularengineering.com - A sideline, not how I earn a living
View Don's profile
Don
517 posts in 3071 days
#2 posted 02-16-2010 10:22 AM
I’ve never worked with solid Zebra wood but I’ve worked with a number of different woods that are very hard and/or have wild grain. If you’re going to work with wood like that you need to invest in either a good drum sander or a planer with a spiral blade. I never run these kinds of wood through a normal planer because they always tear out. My drum sander hanldes them pretty well but I go through a lot of belts due to burning.
-- Don - I wood work if I could. Redmond WA.
View ellen35's profile
ellen35
2738 posts in 3430 days
#3 posted 02-16-2010 02:00 PM
I have worked with zebrawood. It is tough to plane and joint. I think it is because the wood is really 2 different densities. I find that taking off very very very small amounts seems to work. It also requires a ton of sanding afterward. I am going to try some through my drum sander and see if I get better results (just got the drum sander). Hope this helps. I also wonder about wetting it first as some have suggested for other woods that tear out easily.
View Kent Shepherd's profile
Kent Shepherd
2718 posts in 3284 days
#4 posted 02-16-2010 04:40 PM
I’ve used it, and don’t plane it. I do have a widebelt sander though. If you have much to do, you might find a shop in your area with a drum or widebelt sander to sand it for you.
If it is small pieces, hand planes and card scrapers might be a good option.
-- http://shepherdtoolandsupply.com/
View Mike's profile
Mike
93 posts in 3163 days
#5 posted 02-16-2010 09:27 PM
I have done a little work with Zebra but I don’t have a planer. I had good luck resawing on the bandsaw and sanding smooth. It sands very well and quickly.
Good luck
Mike
-- Mike, Cantral Oregon
View Triman's profile
Triman
50 posts in 3580 days
#6 posted 02-16-2010 09:54 PM
I’ve planed, and occasionally have tear out, but 3 things to help:
1) Make sure your blades are scary sharp.
2) Make sure the feed rollers are clean, so as to not have any slipping.
3) Take off only 1/32” at a time.
Even then, you’ll still have some sanding to do!
-- Bruce, San Jose, Ca www.spotofwood.com
TopamaxSurvivor
18270 posts in 3674 days
#7 posted 02-16-2010 11:52 PM
This is what I love about this site. I get answers to questions I didn’t even know were going to come up in teh future:-))
View SawdustWrangler's profile
SawdustWrangler
91 posts in 3396 days
#8 posted 02-17-2010 09:16 PM
I’ve used it a few times and had no trouble with planing it. I use a DeWalt 735 and no problems. The only time I ever have nicks from planing is because I forgot to turn on the shop-vac collecting from the dust hood.
-- Chris, South Carolina
