Starter pin for Jessem Mast-r-lift II
Forum topic by Mark2457 posted 02-16-2016 01:00 AM 809 views 0 times favorited 7 replies Add to Favorites Watch
View Mark2457's profile
Mark2457
49 posts in 1552 days
02-16-2016 01:00 AM
Topic tags/keywords: question
Hi Guys
Anyone know where I can buy one of these (other than Jessem: shipping was double the price of the part)
Thanks
Mark
7 replies so far
View Bob Kassmeyer's profile
Bob Kassmeyer
221 posts in 2893 days
#1 posted 02-16-2016 01:08 AM
Figure out thread size buy a bolt and cut it down. Cost should be around .30 cents and what ever the drive cost you, probably more then double the cost of the part.
-- Bob Kassmeyer, Nebraska
Mark2457
#2 posted 02-16-2016 10:59 AM
- Bob Kassmeyer
Thanks Bob
I did actually think of that, but don’t I need a smooth sleeve to cover the bolt, so the head doesn’t stick out? (never used a starter pin before: just contemplating my first job that uses a pattern bit).
Hardware store is 1 mile away and i’m thre all the time!
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2078 days
#3 posted 02-16-2016 12:36 PM
A block clamped or screwed to the top can serve the same purpose as the pin. All you need is a place to rest the work as you engage the bit.
You could also sleeve the bolt mentioned above with brass, PVC, or copper tube, or even vinyl hose, available elsewhere in the same hardware store.
View bondogaposis's profile
bondogaposis
4687 posts in 2319 days
#4 posted 02-16-2016 01:05 PM
No, you cut the head off.
-- Bondo Gaposis
Mark2457
#5 posted 02-16-2016 07:07 PM
Thanks guys
Will see if I can jerry rig something this weekend
View HokieKen's profile
HokieKen
4747 posts in 1106 days
#6 posted 02-16-2016 07:56 PM
I did actually think of that, but don t I need a smooth sleeve to cover the bolt, so the head doesn t stick out? (never used a starter pin before: just contemplating my first job that uses a pattern bit).
Hardware store is 1 mile away and i m thre all the time!
- Mark2457
If you can find one with the right thread, get a shoulder bolt and grind/cut the head off.
-- Kenny, SW VA, Go Hokies!!!
runswithscissors
2725 posts in 1993 days
#7 posted 02-16-2016 10:00 PM
Or tap threads into the hole and use the shoulder bolt as is.
