Forum topic by lateralus819 | posted 02-15-2016 10:27 PM | 740 views | 0 times favorited | 6 replies | ![]() |
I have to laminate my router top with some formica. How would spray 90 work over the long run? I don’t mind using a roll on type it’s just a big mess. |
#1 posted 02-15-2016 10:37 PM |
it will do the job ! |
#2 posted 02-15-2016 11:59 PM |
I can not recall which of the 3M sprays it is but one of the cans, maybe all, have written instructions for plastic laminates on the can. Be sure to spray both surfaces for a good bond. |
#3 posted 02-16-2016 01:19 AM |
both surfaces will require 2 good coats -- Scott.Triangle,NY Becareful and don't forget...They cut meat too! Ask me how I know |
#4 posted 02-16-2016 01:59 AM |
it’ll work great, spray both surfaces, place long 1/2” pr 3/8” long dowels from the big box story across the top of the table and place your laminate on top of the dowels, check for overhang on all 4 sides and you’re good to go. Take out 1 dowel at the end and attach the top, proceed across the table removing each dowel as you work it down. Some folks use a rubber roller for better adhesion and to flatten the top. After it’s trimmed up we used a metal file to break the edge. |
#5 posted 02-16-2016 02:16 AM |
It’s 3M spray 90 for laminate. One good coat on both surfaces is all you need. Myself, I would buy regular Weldwood contact cement in the can and spread it with a 2 dollar disposable roller. I spray Wilsonart #801 out of a pressure pot. |
#6 posted 02-16-2016 02:32 AM |
Forum | Topics |
Woodworking Skill Share
12035 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1372 |
Finishing
4909 |
6697 |
28073 |
CNC Woodworking
212 |
Hand Tools
5413 |
Jigs & Fixtures
1421 |
Wood & Lumber
6236 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4759 |
LumberJocks.com Site Feedback
2201 |
Coffee Lounge
8847 |
