r4511 vibration
Forum topic by teejay posted 02-14-2010 09:53 PM 1628 views 0 times favorited 13 replies Add to Favorites Watch
View teejay's profile
teejay
95 posts in 3463 days
02-14-2010 09:53 PM
I set up my saw, used a dial indicator and got the blade parallel to the slots. I paralleled my rip fence to the slots and I test cut some wood and there is a ton of saw marks on the wood. Not burns just saw marks.
Any idea as to why? Is it just that the stock ridgid blade is so bad it leaves marks like that?
Thanks
13 replies so far
View ,'s profile
2387 posts in 3744 days
#1 posted 02-14-2010 10:18 PM
I have not even set up my r4511 yet so I cannot speak for the 4511 but I will say my 3650 had a horrible stock blade made by Ridgid. I did not even try to sell the stock blade at a garage sale, I just threw it away recognizing it was not worthy of being used on the worst of saws. Get a real blade and your problem is probably over.
Our 4511 is still packaged up and sitting in the dining room. We are anxious to get it set up soon!
View knotscott's profile
knotscott
8145 posts in 3573 days
#2 posted 02-14-2010 10:24 PM
The stock blade is pretty poor quality, and will ultimate dictate the end performance of your saw. Even if you find something else as the root cause of the problem, you’ll want a better blade. You don’t have to spend a fortune, but if you’re selective $30 and up can usually get you a good blade.
View davidpettinger's profile
davidpettinger
661 posts in 3398 days
#3 posted 02-15-2010 12:36 AM
Try a blade stabilizer and a new blade. Should help greatly.
-- Methods are many,Principles are few.Methods change often,Principles never do.
teejay
#4 posted 02-15-2010 10:58 PM
I threw a dewalt 40t that I happened to have on it and it was so much better. There was a little burn at the front of my crosscut, but that was more b/c I was using the mitre guide alone with a long piece of wood so there was some wobble in the wood I believe.
thanks
View Tim Dahn's profile
Tim Dahn
1570 posts in 3762 days
#5 posted 02-15-2010 11:31 PM
I agree the blade is probably causing the marks. I did not use the stock blade on my R4511, but instead have a Forrest WW2 with the stabilizer and it leaves a perfectly smooth surface. I do notice some vibration when shutting off but that I think is common to this saw.
View lou's profile
lou
343 posts in 3640 days
#6 posted 02-15-2010 11:45 PM
hi teejay.you say that you set the fence parralle with the moter slots.i set the rear of my fence a few thous.away from the rear of the saw blade.other wise the rear of the blade is still touching the wood and causeing marks.not to mention the real problem of kickback or the blade picking up the wood and it being thrown back at you.hope this helps
teejay
#7 posted 02-16-2010 02:28 AM
It is parallel within tolerance. The blade is <.001 and the fence is at about .002
View sh2005's profile
sh2005
97 posts in 3434 days
#8 posted 02-16-2010 04:16 PM
teejay,
I had noticed similar saw marks with the stock blade. With this blade from Infinity Tools, the cuts are much smoother.
How did you get the fence within 0.002? I can’t get my fence being that accurate from the front end of the table to the back end of the blade. I also check the parallelism for the full range of the rip fence position (fence being 24” from blade). So far, I think the root cause of the inaccuracy is the split rail.
View RandyMarine's profile
RandyMarine
236 posts in 3566 days
#9 posted 02-17-2010 04:02 AM
I had the stock belt slip on my R4511….I replaced it and made sure I still had cover and alignment…it worked as it should have.
-- Semper Fi, Randy Sr.
teejay
#10 posted 02-21-2010 07:33 AM
sh2005: I used the same indicator gauge that I bought for $10 to align the fence and blade. The fence is within .002 from front to back, but like others, the center bows in a bit more. I’ll have to address that when I add an auxiliary to it
117328 posts in 3774 days
#11 posted 02-21-2010 07:43 AM
Did you turn it on LOL Hey guy I’m with most the guy’s get a 40 tooth saw blade.
teejay
#12 posted 02-22-2010 12:28 AM
I put a 40tooth on it. I’ll be back out tomorrow to see how it works
sh2005
#13 posted 02-22-2010 10:10 PM
teejay, I use a dial indicator too. I have an auxiliary fence attached now, so I am able to shim where needed. The problem I have is that if I align the fence near perfectly close to the blade, the alignment gets worse when I move the fence all the way out to the right, and vice versa. So, I had choose a middle ground.
I hope the new blade solves the issue.
