Workbench top coating
Forum topic by mags posted 02-14-2010 06:50 PM 9468 views 2 times favorited 12 replies Add to Favorites Watch
View mags's profile
59 posts in 3051 days
02-14-2010 06:50 PM
Topic tags/keywords: question
I am building my first dedicated work bench and I am unsure what to coat it with. Any ideas? thanks
-- Nick,Pa.
12 replies so far
117032 posts in 3511 days
#1 posted 02-14-2010 06:51 PM
Wipe on poly
-- wood crafting & classes
View bigike's profile
4050 posts in 3222 days
#2 posted 02-14-2010 06:54 PM
-- Ike, Big Daddies Woodshop,
View PurpLev's profile
8534 posts in 3582 days
#3 posted 02-14-2010 07:13 PM
BLO – penetrates the wood, seals it from moisture,but leaves the surface rough so that work pieces won’t be flying around. also super easy to apply.
View Derek Lyons's profile
Derek Lyons
584 posts in 3502 days
#4 posted 02-14-2010 07:31 PM
While my workbench is still in the planning stages – I’ll be going with BLO or something similar. You want the top ‘natural’ rather than turned into a skating rink.
-- Derek, Bremerton WA --
View Hugh's profile
65 posts in 3068 days
#5 posted 02-14-2010 08:04 PM
I found this article. Maybe it will help.
-- Magnolia, Texas
View Les Casteel's profile
Les Casteel
160 posts in 2993 days
#6 posted 02-14-2010 08:16 PM
I use wipe-on Poly on the sides, legs, drawers. Then for the top I rubbed in BLO thinned down with paint thinner. I applied a thin coat every day for about 10 days until it wouldn’t take any more. Then a light coat every now and then or if I scratch it.
My German grandfather toad me a good craftsmen will build 3 benches in his lifetime, each one better than the last. Good luck with the first one!
-- Les, Missouri,
View hokieman's profile
181 posts in 3688 days
#7 posted 02-14-2010 10:10 PM
I used Boiled Linseed Oil. Works great.
View woodmight's profile
113 posts in 2990 days
#8 posted 02-14-2010 11:00 PM
Well I covered my entire bench top with Hard Board (screwed on) then in a couple of years when it gets all dirty and covered with paint, coffee stains, and you can start to tell what I have had for lunch for the past few years, and what ever. I just unscrew the top and replace it.. Bingo a new bench top !! Works Great..
-- ~~ Remember You can't saw... What you can't see ~~
View mags's profile
#9 posted 02-15-2010 03:27 AM
I want to thank all you guys that answered my question. and I see by a 95% majority BLO is the way to go for the top and what ever I want for every other surface. And hugh thanks for the article that helped a lot. thanks again Nick M.
-- Nick,Pa.
View bobkberg's profile
439 posts in 3007 days
#10 posted 02-16-2010 08:21 AM
Personally, I use Minwax (I can hear the groans now) Sanding Sealer – which gets re-done every couple of years. Just make sure you let it dry for a week. I also go back and filll any gouges with wood putty and sand it flat first.
-- Bob - A sideline, not how I earn a living
View Jeison's profile
968 posts in 3041 days
#11 posted 02-16-2010 11:59 AM
great link, good stuff to know for us rookies :D
-- - Jei, Rockford IL - When in doubt, spray it with WD-40 and wrap it with duct tape. The details will attend to themselves.
View SBOhio's profile
24 posts in 2995 days
#12 posted 02-16-2010 03:00 PM
What is Baily’s Booth Coat?
