Glue question, kind of......
Forum topic by westside posted 02-14-2010 05:39 PM 1708 views 0 times favorited 21 replies Add to Favorites Watch
View westside's profile
westside
77 posts in 3080 days
02-14-2010 05:39 PM
Has anyone ever seen the rolling glue bottle that Norm Abrams uses on New Yankee Workshop? Where would you find that ? I went on The NYW website looking under tools for sale and only saw the biscuit glue bottle he uses for gluing up bis biscuits. It is a pain in the neck sometimes when I’m gluing work up and I thought it would be so much easier if I could buy one of those rolling glue bottles.
Thanks in advance, Rich
21 replies so far
View hObOmOnk's profile
hObOmOnk
1381 posts in 4092 days
#1 posted 02-14-2010 05:51 PM
Lee Valley
-- 温故知新
Rick Dennington
5805 posts in 3159 days
#2 posted 02-14-2010 06:02 PM
Greetings westside: You can find them at about any place that sells ww supplies. Rockler, Woodworkers Supply, Amazon, you name it…... I have 2, and I don’t like either one. I’d much rather use glue straight from the bottle, and spread it with a flux or small cheap brush….. that’s just me though…. you can find them. If no luck, check with Kent Sheapard (he’s a LJ on this site). He owns a woodworking store, handles Rockler products, and other good quality brands. Kent’s on here quite a lot, so just PM him if you need to…... later.
View syenefarmer's profile (online now)
syenefarmer
486 posts in 3045 days
#3 posted 02-14-2010 06:11 PM
I’m with Rick on this. I’ve used one in the past and didn’t care for it.
View lew's profile
lew
12017 posts in 3720 days
#4 posted 02-14-2010 06:14 PM
I’ll add to that as well. Have one but found it easier to use the regular glue bottle and a brush (or finger- which explains why my shop apron can stand up by itself). Also found the roller bottle was a hassle to clean after each use.
View Sawkerf's profile
Sawkerf
1730 posts in 3033 days
#5 posted 02-14-2010 06:21 PM
I have a Rockler setup that includes the roller as well as several bottle tips. I used it for a while after I got it, but gave it up after getting tired of constantly having to clean it.
I haven’t used the tips or bottle for years and sometimes use just the roller when I need to spread glue fairly quickly.
As others have said, it’s more trouble than it’s worth.
View Bruce's profile
Bruce
199 posts in 3739 days
#6 posted 02-14-2010 06:45 PM
any way u do it glue-up is messy.
-- I think of Jack Nicholson as the Joker in Batman when he says "Where does he get those wonderful toys" and ask WHERE DO U GUYS GET ALL THAT WONDERFUL WOOD?
117062 posts in 3541 days
#7 posted 02-14-2010 06:48 PM
Stopped using mine years ago.
View russv's profile
russv
262 posts in 3134 days
#8 posted 02-14-2010 07:21 PM
i had one and didn’t like it.
i don’t roll glue often, but when i do, i have a plastic roller on a metal handle that i can throw into water for easy clean up. the bottle with the roller makes clean up impossible.
russv
-- yknotwood.com: where to go because you don't want no stinking plastic!
westside
#9 posted 02-14-2010 07:52 PM
Thanks for all the responses.I did not realize what a pain in the neck it was to use. Norm makes it look so easy. Where can you find glue in a bottle? I use the kind in a squeeze bottle is a pain in the neck as well. It tends to lock up if not used on a regular basis and have to be cleaned out using a small pick or nail to clean and open it back up again. Thanks all for your help. Much appreciated.
View Brian024's profile
Brian024
358 posts in 3364 days
#10 posted 02-14-2010 08:06 PM
I’m on the opposite side of the fence, but I have one and would not be without it. It may be a pain to clean but I’ve found it helps in speed. I glue up things a lot faster when I use one than when I don’t. I think I bought it at Woodcraft for like $10.
View Les Casteel's profile
Les Casteel
160 posts in 3024 days
#11 posted 02-14-2010 08:09 PM
I had one, hated it. Threw it away and bought a Glu-bot with replaceable parts. Then I use a flux brush or my finger to spread it.
-- Les, Missouri, www.woodthatrocks.com
View closetguy's profile
closetguy
744 posts in 3856 days
#12 posted 02-14-2010 08:13 PM
I got mine from Lee Valley, and like everyone says, clean up is a pain. I just use shop towels cut into quarters to spread the glue and throw it away after I’m done spreading.
-- I don't make mistakes, only design changes....www.dgmwoodworks.com
View Tony_S's profile
Tony_S
857 posts in 3047 days
#13 posted 02-14-2010 08:26 PM
Yep….nothing but a PITA. Betcha Norm (really) hates his as well…
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
27250 posts in 3786 days
#14 posted 02-15-2010 01:22 AM
If you would like one more comment that the tips are a PITA here is mine. But I do use the roller when I have an especially large area to apply glue to. But I use just the roller as a spreader. The tips are almost worthless in my opinion.
I do like the plastic bottles of glue and will re-fill them when they are empty. You are right about the clogging. But I have found that if I close the spout and wipe it cleam with a towel it really cuts down on the plugging and subsequent cleaning of the dried glue.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3445 days
#15 posted 02-15-2010 02:07 AM
I didnt like mine either. I run a bead of glue on the board edge and take a small brush and even it out.
-- Wayne - Plymouth MN
