Fix a Cherry Finish
Forum topic by Twolukes posted 02-15-2016 02:54 PM 824 views 0 times favorited 9 replies Add to Favorites Watch
View Twolukes's profile
Twolukes
5 posts in 740 days
02-15-2016 02:54 PM
Topic tags/keywords: cherry finish blo bookmatched
I built new cherry doors and drawer fronts for my bathroom and finished them with BLO, left them in the sunroom for 2 months and they aren’t dark enough. Need some advice on how to get them darker without losing the grain. I haven’t put anything on them except the BLO, Thanks!
9 replies so far
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2018 days
#1 posted 02-16-2016 12:32 PM
I might have either cut off or dyed the sap, but it’s too late for that…
Have any scrap left? You could experiment with spraying on some tinted clear coats. You’ll need to spray them, as it’s super difficult to get them even with a brush, rag or pad.
By the time you’re done experimenting, your panels may have reached a darker color. You could also try Tanning or Gro-Lamps at night, giving them 24 hr. sunlight.
View pjones46's profile
pjones46
1000 posts in 2550 days
#2 posted 02-18-2016 03:47 AM
Try some Watco Danish Oil, Cherry color, on scrape to see if that will suit you. You can use multipal coats to obtain a deeper color.
-- Respectfully, Paul
View 01ntrain's profile
01ntrain
237 posts in 978 days
#3 posted 02-18-2016 03:56 AM
OK….kind of a newbie, here. What is BLO?
pjones46
#4 posted 02-18-2016 04:06 AM
aka Boiled Linseed Oil
View BurlyBob's profile
BurlyBob
5250 posts in 2173 days
#5 posted 02-18-2016 06:04 AM
Black walnut or ebony!!!!
View MNgary's profile
MNgary
296 posts in 2325 days
#6 posted 02-20-2016 05:54 AM
Just my thoughts and, I am certain, others will diagree!
The blo has sealed the surface so dyes cannot not penetrate and stains will only dry on the surface leaving a muddy appearance lacking depth. Hence, you can darken (and lose tranparency/natural beauty) using colarants or accept this is the new look. Your choice .
-- I dream of the world where a duck can cross the road and no one asks why.
View TheTurtleCarpenter's profile
TheTurtleCarpenter
1007 posts in 974 days
#7 posted 02-20-2016 06:26 AM
The BLO might be hindering the wood from darkening quick enough to suit you. Try rubbing down the doors with turpentine or mineral spirits with steel wool and then expose them to the sunlight,,this could be done several times. If that doesn’t work you could try the Mineral spirits again and mix in a little cherry stain to the spirits,,,a little amount at a time. Try it on the backs first. Good Luck.!
Jeff
-- "Tying shoelaces was way harder than learning to Whistle",,,,,member MWTCA area K. Kentucky
TheWoodenOyster
1313 posts in 1843 days
#8 posted 02-20-2016 02:44 PM
I don’t know. Without staining them, I’m not sure how much darker you are going to be able to get them. You might have to remove the BLO if possible and stain or dye.
-- The Wood Is Your Oyster
View ChefHDAN's profile
ChefHDAN
1010 posts in 2757 days
#9 posted 02-20-2016 03:35 PM
The cherry will continue to age over the years even under the BLO. I added a pic to this project to show the aged color after 4 years, and the table lives in a hallway that does not really get direct sunlight
