A couple of questions about wenge...
Forum topic by Vick posted 02-14-2010 01:33 AM 2497 views 0 times favorited 6 replies Add to Favorites Watch
View Vick's profile
Vick
49 posts in 3013 days
02-14-2010 01:33 AM
Topic tags/keywords: wenge bandsaw tablesaw question milling veneering
Here’s the situation. I would like to edge band a board with some wenge. I can to it with two strips, each 40 inches long. However, my piece of wenge is only 26 inches long, but 2 1/2 inches wide.
1) I saw on DIY a brief clip on how to turn a short board into a long board by cutting from one corner to the opposite corner down the length and re-gluing while offset to the desired length. Is it really that easy? I’m asking before I start cause I don’t want to jack up this piece of awesome wenge.
2) Once cut into 1/8 in wide strips (if the above process works), can I soak/steam the wenge strips so they will bend around the corners of the piece to be banded? I have heard that wenge can easily splinter. Just wondering if the whole process is worth it before I hack up this piece of wenge.
Thanks for the advise!
Vick
-- Good energy perpetuates good energy!
117063 posts in 3547 days
#1 posted 02-14-2010 02:50 AM
I ‘ve done the stretching the board routine . when you do that you loose width.but I don’t feel good about the bending around corners with a wood like wenge but Unless you steam it, and even with out the glue I still would feel that there’s a chance it could break. How about using some oak and dyeing it close to the wenge color.
View Tony_S's profile
Tony_S
857 posts in 3052 days
#2 posted 02-14-2010 04:01 PM
Ive done a fair amount of inlay work with Wenge, much of it curved. All said, it’s a fairly ignorant wood to bend around a radius much tighter than about 10-12 inches. The Wenge I worked with was 1/4” x 1/4” after milling, and pretty much had me pulling my hair out during the tighter bends. It’s a very hard, (and even worse) brittle wood.
Steaming(I have no experience steaming Wenge)...unless the Wenge has been air dried vs. kiln dried, which I assume you don’t know….is a waist of time.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
16274 posts in 4188 days
#3 posted 02-14-2010 04:31 PM
I don’t think you could stretch a 26” board to 40” and still have enough width to work with, but in a coarse wood like that, I don’t think an angled lap joint would be noticeable.
And I can’t see bending wenge around tight corners. Are we talking square corners or what radius?
13600 posts in 3311 days
#4 posted 02-14-2010 04:41 PM
i don’t think i would even try to bend wenge , ( more than slightly ) .
and steaming it would probably soften the glue ,
as charlie said ,
an angled lap ,
or some ’ plinth ’ block in the middle as novelty .
View Vick's profile
Vick
#5 posted 02-14-2010 08:49 PM
the radius of the coners is about 2 inches. So what y’all are saying is don’t waste the wenge… got it! Thanks for the advise!!
View cathyb's profile
cathyb
768 posts in 3214 days
#6 posted 02-14-2010 09:12 PM
Wenge is not the best choice for bending. It is brittle and if you don’t have a splinter yet, YOU WILL. Walnut bends well, I’d use that instead.
-- cathyb, Hawaii, www.cathyswoodworking.com
