Another question on my router tabletop
Forum topic by sikrap posted 02-13-2010 11:23 PM 1393 views 0 times favorited 7 replies Add to Favorites Watch
View sikrap's profile
sikrap
1121 posts in 3356 days
02-13-2010 11:23 PM
Well, I’m just about done with the router table (pics to follow soon). I have the top done, the plate installed and the router mounted. Now all I need to do is install the T-track for the fence and a slot for the miter track. The miter track will be easy, although I may decide not to bother, but I want to install some T-track to secure the fence. The routing for the track will be easy enough, but how do I square the end? I don’t want to have an opening. Chisel it out? Leave it and let the fence hide it? Say “to hell with it” and just clamp the fence? Thanks!!
-- Dave, Colonie, NY
7 replies so far
117091 posts in 3574 days
#1 posted 02-14-2010 12:36 AM
If your going to use a miter square or coping sled you will pretty much need it open on the end. Usually I just do a set measurement form the outside edge. Routers are centered in your work there not like a saw that you have to have it perfectly square with the blade.
sikrap
#2 posted 02-14-2010 03:57 AM
I know what to do for the miter track, its the Grooves for the t-track that I don’t understand. If I just rout dados to drop the track in, the dados will be rounded where I stop routing. The t-track will be square on the ends. How will I square off the end of the dado?
#3 posted 02-14-2010 04:01 AM
You just carefully chisel it out.
sikrap
#4 posted 02-14-2010 05:30 AM
Okay, thanks!!
View Ger21's profile
Ger21
1074 posts in 3128 days
#5 posted 02-14-2010 04:32 PM
Rather than chisel it out, try filing the track round on the end.
-- Gerry, http://www.thecncwoodworker.com/index.html http://www.jointcam.com
View Mean_Dean's profile
Mean_Dean
6477 posts in 3144 days
#6 posted 02-17-2010 08:10 AM
What’s funny, is that I’m at this exact stage myself!
I’m about 99% finished with my router table, and just need to rout and install the T-tracks, and miter track. I was pondering this very same queston!
What concerns me a little is getting the exact depth for the slots. I’ll be using a hand-held router, so this could be a little tricky. But I’m going ahead with it tomorrow. Wish me luck!
-- Dean -- "Don't give up the ship -- fight her 'till she sinks!" Capt James Lawrence USN
Rick Dennington
5858 posts in 3192 days
#7 posted 02-17-2010 08:28 AM
Greetimgs Mean Dean: One sugesstion for you: When you rout for the T-Tracks, make the depth of the slots just a hair deeper than the depth of the T-Tracks. That way when you slide a workpiece across the router table, it won’t hang up on the edge of the track, and will slide smoothly…....good luck…... later.
