I am a terrible saw sharpener, but I am having fun
« back to Hand Tools forum
Forum topic by CB_Cohick posted 02-14-2016 02:52 AM 1366 views 0 times favorited 29 replies Add to Favorites Watch
View CB_Cohick's profile
CB_Cohick
484 posts in 1217 days
02-14-2016 02:52 AM
Topic tags/keywords: sharpening crosscut saw
I picked up a nondescript Warrented Superior 8 ppi crosscut saw while rust hunting today. If nothing else, it is good practice for sharpening. The points are getting plenty “sticky” sharp, the way a sharp saw feels, you know what I mean. Swapping out my worn file for a fresh one was a big help. The biggest problem I see with what I am doing is maintaining even tooth height, as you can see in my photo. Anybody have a handy tip or three?
Thanks in advance.
-- Chris - Would work, but I'm too busy reading about woodwork.
29 replies so far
View sawdustdad's profile
sawdustdad
354 posts in 851 days
#1 posted 02-14-2016 04:19 AM
Joint the teeth with a flat file so that a bright spot appears on the tip of every single tooth. Then, file to sharpen the teeth until that flat spot JUST disappears on each tooth. the will all be the same height.
-- Murphy's Carpentry Corollary #3: Half of all boards cut to a specific length will be too short.
CB_Cohick
#2 posted 02-14-2016 04:43 AM
- sawdustdad
That is a great tip, and that was actually the first thing I did. What I noticed about my pattern is that it seems to be an every other point problem. Since I am trying to file crosscut, my grip\stance is changing every other tooth also. I wonder if it would be advantageous to file every other tooth toe to heel, then flip the saw in my vice and hit the other teeth, but maintain my same grip\stance. Another thing I have noticed as I progressed from the original photo is that if I don’t bear down as much on my file, and let the tool do the work, then my consistency improved greatly.
View BurlyBob's profile
BurlyBob
5409 posts in 2232 days
#3 posted 02-14-2016 04:54 AM
My hat’s off to you . I haven’t gotten the nerve yet to try sharpening saws.
CB_Cohick
#4 posted 02-14-2016 05:00 AM
Bob, I forget which LJ it was that gave me some initial encouragement, but basically the advice was just to go for it and that in their experience they had never made a dull saw worse for trying. It is something I see myself getting better at.
BurlyBob
#5 posted 02-14-2016 05:05 AM
Chris, That is a great piece of advice. Sounds like a piece of advice an old mentor of mine would have given me.
I was building a small garden shed and he saw me trying to get a very precise measurement cut exactly. He told me, ” You ain’t building a piano.”
View summerfi's profile
summerfi
3882 posts in 1653 days
#6 posted 02-14-2016 05:09 AM
Chris, you’re a brave man starting out with a crosscut. Rip saws are easier to file by a factor of 10 and are what most people start with. I’m assuming you’ve already watched Andy’s video. If not, it’s a must. I can tell from your picture that one of the problems you’re having is filing more rake on one side of the saw than the other. After shaping the teeth, it is critical to maintain that same rake angle on both sides. Proper lighting is valuable for this. When I file a crosscut saw, I usually do it at night, in the dark, with only my bench light shining on the teeth. I can immediately tell from the reflection if I’m keeping the correct rake angle.
-- Bob, Missoula, MT -- Rocky Mountain Saw Works http://www.rmsaws.com/p/about-us.html
View James Wright's profile
James Wright
331 posts in 830 days
#7 posted 02-14-2016 01:30 PM
I cut a curf in a small block of wood at the angle I want to file and place the block over the saw so that I have a constant reference to the angle I am filling. I file every other to keep the angle the same. then after I flip the block over and do the other set.
-- James Wright, Rockford IL, https://www.youtube.com/c/WoodWright
View dddddmorgan's profile
dddddmorgan
87 posts in 1094 days
#8 posted 02-14-2016 01:37 PM
James hit on something important here. The best way to file a saw is all one cut then switch to the opposite. Makes everything more consistent and accurate. Even a fancy powered saw Finley like the Foley-Belsaw makes you flip the saw.
-- Maintenance Man - I do precision guesswork based on unreliable data from people of questionable knowledge...
View JayT's profile (online now)
JayT
5588 posts in 2177 days
#9 posted 02-14-2016 01:54 PM
I wonder if it would be advantageous to file every other tooth toe to heel, then flip the saw in my vice and hit the other teeth, but maintain my same gripstance.
- CB_Cohick
That will help a lot. Switching every tooth really hurts consistency.
Is the saw vise working for you or did you have to build one?
CB_Cohick
#10 posted 02-14-2016 02:11 PM
Jay, that vise is working very well for me. Thanks again!
CB_Cohick
#11 posted 02-14-2016 04:30 PM
I have taken your thoughts into consideration and see some improvement. I still need to work on some of the points where I marked the tops of the teeth, but I feel like my condistency is better. I am paying more attention to rake, and working one side at a time seems to help quite a bit. Thanks, everyone.
View duckmilk's profile
duckmilk
2771 posts in 1291 days
#12 posted 02-14-2016 06:30 PM
Looking good Chris, you’ll get the hang of it. Here are a couple of links to Andy’s video and also his saw blog. These will give you hours of entertainment.
http://lumberjocks.com/Brit/blog/36332
http://lumberjocks.com/Brit/blog/series/4708
-- "Duck and Bob would be out doin some farming with funny hats on." chrisstef
View Don W's profile
Don W
18685 posts in 2534 days
#13 posted 02-14-2016 11:30 PM
You definitely want to sharpen one side at a time.
You might be younger than me, but I find these invaluable.
View hotbyte's profile
hotbyte
991 posts in 2942 days
#14 posted 02-15-2016 12:10 AM
I’d look like I was boarding the mother ship with those on :-) I bet they do help wonders, though!
Interesting thread…I’ve not ventured into saw sharpening, yet.
- Don W
CB_Cohick
#15 posted 02-15-2016 12:34 AM
- Don W
Don, those look interesting. Where would I go to look at them? Got a link, brandname?
showing 1 through 15 of 29 replies
