Portable shop on wheels
Forum topic by Dennis Fletcher posted 1221 days ago 3119 views 0 times favorited 17 replies Add to Favorites Watch
View Dennis Fletcher's profile
Dennis Fletcher
455 posts in 1251 days
1221 days ago
Topic tags/keywords: resource jig question
Well, after seeing many projects here that have been made out of everyday things, especially the miter saw on the grill base, i have been thinking of beginning to make my shop a bit more portable, adding wheels to everything so I can pull it out of the shop on decent days to gain more room.
I love the saw idea, but I will need larger wheels, thinking for the fact that it is somewhat rough here, but the grill wheels may just be large enough.
I am thinking that the miter saw and the router could have it’s own stands, possibly making a large bench on wheels, since I never have enough bench top room.
I’m not sure about the drill press, it may be fine where it is.
Do you find that things on wheels make it easier for you?
-- http://www.ahomespecialist.net, Making design and application one. †
17 replies so far
View mikedrums's profile
mikedrums
102 posts in 1233 days
#1 posted 1221 days ago
Wheel are great and a necessity for me because the shop is so small.
Two important things to keep in mind….
1. don’t skimp on the wheels. bigger is generally better. Harbor freight has sales on their casters all the time. Check through the stock to pick the ones that aren’t too loose in the bearings. HD and Lowes have four-packs that go with their big metal shelving units, and they have locks on them… which leads to…..
B. some tools need to be locked down when using. Any tool on which your will be pushing heavy stock in one direction will need to have lockable wheels or wheels that adjust up and down.
Here are a few of mine.
http://mikedrums.com/benchwheels.mov
http://mikedrums.com/castercam.mov
http://mikedrums.com/routertablewheels.mov
http://www.mikedrums.com/tablesawwheels.mov
89049 posts in 1774 days
#2 posted 1221 days ago
I’ve seen to good portable shops One is on a HGTV on Carter can and another fold out one in and old Finewoodworking Magazine.
Dennis Fletcher
#3 posted 1221 days ago
Thanks, I was originally thinking about larger wheels, like from wheelbarrows, but that just seems too large.
I can see my table saw and router needing to be locked down, but not sure the table would need it. Also, I thought about making it so that it lifts like a wheelbarrow, making it lock down automatically.
View UnionLabel's profile
UnionLabel
660 posts in 1397 days
#4 posted 1221 days ago
My whole shop is going to be mobile. I have been working over the winter to get it done. Only have the drill press left. I am also going to redo the tablesaw. I will be using 4” casters. It is currently on 2 1/2” casters but compared to the weight, they just don’t work well. My RAS is on the woodcraft casters that are foot lever operated, my router cabinet is on bench dog casters with levelers. I am using shop fox mobile bases for everything else.
-- Methods are many,Principles are few.Methods change often,Principles never do.
34396 posts in 2597 days
#5 posted 1221 days ago
I agree on the drill press. The floor stand ones are a little top heavy.
I’ve got wheels on just about all tools. If nothing more than to give a little more room when using them.
View John Gray's profile
John Gray
2364 posts in 2082 days
#6 posted 1221 days ago
My drill press is the only floor standing power tool I have that’s not on wheels and I think the drill press is top heavy enough without putting wheels under it.
View cstrang's profile
cstrang
1747 posts in 1365 days
#7 posted 1221 days ago
The only “stationary” power tool I don’t have on wheels is my table saw, everything else is mobile and I wouldn’t have it any other way!
-- A hammer dangling from a wall will bang and sound like work when the wind blows the right way.
mikedrums
#8 posted 1221 days ago
The trick to having a drill press on wheels is to only have two wheels, so it must be tilted to be rolled. That way, you are always in control of the weight.
Like this guy did with his saw…
http://www2.gol.com/users/nhavens/resource/bt3k10.jpg
With a drill press, the wheels would go on the front, instead of the back, so when you pull it back towards you, it would engage the wheels.
View Sawkerf's profile
Sawkerf
1730 posts in 1265 days
#9 posted 1220 days ago
I built these “carts” for my router/shaper and planer. They have two wheels and two “legs” so they can be moved if needed. I mostly did them for the drawers. Is there ever enough space for your “stuff”? – lol
http://i1023.photobucket.com/albums/af359/Dave1945/Miscellaneous/DSC00391Small-1.jpg
http://i1023.photobucket.com/albums/af359/Dave1945/Miscellaneous/DSC00387Small.jpg
http://i1023.photobucket.com/albums/af359/Dave1945/Miscellaneous/DSC00388Small.jpg
View Derek Lyons's profile
Derek Lyons
584 posts in 1765 days
#10 posted 1220 days ago
Thing on wheels make it immensely easier for me.
I’ve already built this cart;
Click for details
But in the next year or so will be building more.
-- Derek, Bremerton WA --
View BigG's profile
BigG
56 posts in 1266 days
#11 posted 1220 days ago
Yup, small shop so everything is mobile. especially nice on pretty days when you have a lot of repetitive ‘dust ’ to make.
-- Big G
View Rob67's profile
Rob67
25 posts in 1192 days
#12 posted 1182 days ago
I agree that wheels are great. Just be aware that wheel sraise the level of the surface you are working on. If you are tall this may be a blessing but if you are short it may be a problem.
Derek Lyons
#13 posted 1181 days ago
It’s the length of the leg that determines the height of the working surface Rob. If you add wheels, just shorten the leg appropriately.
View Michael Murphy's profile
Michael Murphy
448 posts in 1202 days
#14 posted 1181 days ago
Here’s a portable shop on wheels. I wonder if the equipment is included.
http://sacramento.craigslist.org/tls/1660578975.html
-- Michael Murphy, Woodland, CA.
View DebraB's profile
DebraB
7 posts in 1192 days
#15 posted 1178 days ago
Here’s a base I like – though I would use a bit of metal in the corners.
It keeps the tool on all 4 legs except when you need to move it around.
http://www.youtube.com/watch?v=Ko3-Lzt7BFY
