PLEASE HELP! Miter saw out of square
Forum topic by ardbeg posted 02-13-2010 03:15 PM 1194 views 0 times favorited 9 replies Add to Favorites Watch
View ardbeg's profile
ardbeg
102 posts in 2898 days
02-13-2010 03:15 PM
I don’t really understand this, but somehow my PC compound miter saw (3802L) seems to be cutting trapezoids. The fence is fixed so that can’t be it (I think) and the table is locked down at 0. Maybe this is a stupid noobie mistake but I have used it for 6 years without this ever happening and this morning it won’t give me true cuts. What do I do now? Thanks in advance for your help, Gus
-- You may delay, but time will not. --Ben Franklin
9 replies so far
View Dennis Fletcher's profile
Dennis Fletcher
467 posts in 2925 days
#1 posted 02-13-2010 03:22 PM
This may sound dumb, but have you checked the blade? I have had a saw cut bad suddenly, I had to tighten the blade. Just thinking.
-- http://www.ahomespecialist.net, Making design and application one. †
View blockhead's profile
blockhead
1475 posts in 3178 days
#2 posted 02-13-2010 03:26 PM
Did you check the fence and blade for square? If not, make sure you use a square that you know is a true square. It may just need a small adjustment which you should be able to find in your manual. It is not uncommon for MS to need adjustments from time to time.
-- Brad, Oregon- The things that come to those who wait, may be the things left by those who got there first.
13594 posts in 3211 days
#3 posted 02-13-2010 03:37 PM
to check for square ,
use a straight parallel board ( scrap ) ,
and flip one side after crosscutting ,
if it is square , it will close exactly ,
if not , you will have a ’ v ’ on one side or the other .
adjust accordingly .
blockhead
#4 posted 02-13-2010 04:15 PM
I agree with patron, better method than what I suggested.
ardbeg
#5 posted 02-13-2010 04:18 PM
Thanks guys. That is exactly what happens with the squared board. I will go try to figure out how to adjust it. Anyone have any hands-on experience with this in a Porter Cable?
#6 posted 02-13-2010 04:32 PM
there has to be some adjusment somewhere there ,
i don’t know that tool ,
but they all have it ,
i did work with a hitachi ,
that had that problem ,
and it was the fence that could be adjusted ,
i had never seen that before ,
but and allen wrench and a little tweeking , and good to go .
ardbeg
#7 posted 02-13-2010 04:49 PM
Thanks Patron. It turned out to be the fence on here too. It is bolted on and apparently got bumped.
View Dark_Lightning's profile
Dark_Lightning
3018 posts in 2979 days
#8 posted 02-13-2010 05:07 PM
Make sure that fence is good and tight! That must have been one serious bump. On my PC compound miter saw, there is an adjusting screw under the locking knob that has an eccentric on it. You loosen the nut and turn the screw to get it into square. I had just mitered a set of oak boards to make a window frame style picture frame, and the alignment was terrible.
-- Random Orbital Nailer
116804 posts in 3447 days
#9 posted 02-13-2010 05:46 PM
Glad you found your problem.
