Homemade table saw
Forum topic by ashahidan posted 1222 days ago 12520 views 0 times favorited 35 replies Add to Favorites Watch
View ashahidan's profile
ashahidan
32 posts in 1296 days
1222 days ago
Topic tags/keywords: saw machine tool diy table saw question
I am thinking of making a 12 ” table saw as I couldn’t afford to get a commercial one. I can purchase all the parts
here and assemble a simple saw. I have a rough idea on how to make one.
But do you think it safe to make and use a homemade table saw?
ashahidan
-- asm
35 replies so far
View Eagle1's profile
Eagle1
2042 posts in 1262 days
#1 posted 1222 days ago
I think that you could do it. The only thing I would be concerend about, is what you are going to use for the table top.
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
View Jei'son's profile
Jei'son
946 posts in 1305 days
#2 posted 1222 days ago
I have no doubt it could be done, I’ve seen shopmade versions of every other kinda tool.
-- - Jei, Rockford IL - When in doubt, spray it with WD-40 and wrap it with duct tape. The details will attend to themselves.
Jei'son
#3 posted 1222 days ago
Heh, just happened to be flipping through some back issues of ShopNotes and spotted this….
View Ger21's profile
Ger21
594 posts in 1328 days
#4 posted 1222 days ago
I’ve seen a homebuilt table saw in a really old issue of FWW.
-- Gerry, http://home.comcast.net/~cncwoodworker/CNC_Woodworker.html
89108 posts in 1774 days
#5 posted 1222 days ago
I think it’s an interesting idea but I think you should be able to buy a used saw for less than what parts will cost you.
ashahidan
#6 posted 1211 days ago
Many thanks to:
Aagle1,
I was thinking of using a 3/4 inch plywood for the top. But I think a 1/4 inch ms plate would be a better choice except for the cost.
Jei’son (the picture of the table saw: it scares me ! ) .
Ger21.
a1 Jim:
But Jim, I already have a one horsepower motor ,two bearing blocks , a set of pulleys and a shaft (made by a machine shop). Not much more to buy other than materials for the table legs and the saw top.
Thanks everyone.
ashahidan
-- asm
View Sawkerf's profile
Sawkerf
1730 posts in 1266 days
#7 posted 1211 days ago
Personally, I wouldn’t want to use a home made table saw of any size – let alone a 12”er. I feel quite comfortable using a “commercial” TS, knowing that it’s design and construction (as well as some common sense on my part) should let me keep my body parts intact and my blood contained.
I doubt if I would feel that way about a home built version. – lol
View WayneC's profile
WayneC
9589 posts in 2294 days
#8 posted 1211 days ago
Check this out
http://www.vintageprojects.com/power-tools/table-saw.html
http://www.vintageprojects.com/power-tools/saw-sander-tilt.html
View russv's profile
russv
262 posts in 1366 days
#9 posted 1210 days ago
just curious, why a 12” saw?
would it be expensive to ship one from here to Malaysia?
russv
-- yknotwood.com: where to go because you don't want no stinking plastic!
View richgreer's profile
richgreer
4472 posts in 1272 days
#10 posted 1210 days ago
In my opinion, it is possible to make a safe, homemade table saw if you don’t include the feature that allows you to change the angle of the blade. You could control the depth of the cut by raising and lowering the table. Without the tilting feature, you are talking about pretty simple machinery. A motor, a belt, some bearings, and a blade in a solid wooden structure.
The number one safety factor is the person using the saw.
For what it is worth – - Many years ago I rigged up a table saw by turning a hand held circular saw upside down and mounting it in a table. It worked. But I had no height or tilt adjustment capabilities.
russv
#11 posted 1210 days ago
rich,
that’s why i was wondering about why a 12” saw before. you can easily build a table to accept a circ. saw. i also did that once. I was able to use the tilt and height adjustment features of the circ. saw on my table. on some cuts, i would take the saw out and use it.
the only issue with this idea, you’re not going to get a 12” capacity out of a circ saw.
designing and building your own wouldn’t be that hard though. I would mount the table so it can be raised and lowered. i would mount the motor independent and adjust it for the angle adjustments. piece of cake.
I saw on an earlier post a tablesaw where the table top tilted. To me, that’s an accident waiting to happen. I don’t even like tilting my bandsaw table (but I do sometimes). but a tablesaw top tilted makes controling the wood harder and more dangerous.
russv
richgreer
#12 posted 1210 days ago
russv – I agree completely. Many years ago I began with a ShopSmith. I’m still a ShopSmith fan but my number one complaint about them is tilting the table instead of tilting the blade. it is hard (very hard sometimes) to control the wood on a tilted table.
View Sarit's profile
Sarit
451 posts in 1337 days
#13 posted 1210 days ago
Hmm, balancing on one foot while pumping w/ the other while keeping a piece of wood tightly pressed to a miter gauge while sliding it down a tilted table towards a spinning blade of death… yep, don’t see anything wrong with that.
View sambo56's profile
sambo56
13 posts in 1211 days
#14 posted 1210 days ago
My very first table saw was a circular saw bolted under a 3’ x 3’ plywood table which straddled two sawhorses.
I used a homemade wooden fence that I just clamped on.
I used it to make kids picnic tables that I sold from the front of my parents lawn when I was about eighteen or so. I sold quite a few.
Man, that’s almost 35 years ago.
-- Rick, Canada, http://www.table-saw-guide.com
View Thos. Angle's profile
Thos. Angle
4400 posts in 2159 days
#15 posted 1210 days ago
The bigger problem I see is the 1 horse motor. My Jet had a 3 horse motor and I would have liked a 5. I don’t think a 12 inch blade will work very well on a 1 horse motor.
showing 1 through 15 of 35 replies
