Magnetic switch.
Forum topic by 716 posted 02-13-2016 05:44 AM 890 views 0 times favorited 14 replies Add to Favorites Watch
View 716's profile
716
502 posts in 786 days
02-13-2016 05:44 AM
I need a small clarification here:
Is “magnetic switch” a device that disconnects during power loss and stays off when the power is restored until turned on manually?
-- It's nice!
14 replies so far
View 01ntrain's profile
01ntrain
231 posts in 940 days
#1 posted 02-13-2016 05:48 AM
Yes!
View 716's profile
716
#2 posted 02-13-2016 05:55 AM
I am asking because the manual to my Grizzly hybrid in many places refers to a “magnetic switch”, which I remember back from my childhood worked as I asked in OP. However I had a power loss and left the shop. I cannot describe my horror when the power restored and I heard the table saw running by itself in the garage.
-- It's nice!
View AlaskaGuy's profile
AlaskaGuy
3756 posts in 2179 days
#3 posted 02-13-2016 07:57 AM
Karma says “if anything can go wrong, it will”
View BonPacific's profile
BonPacific
20 posts in 725 days
#4 posted 02-13-2016 08:01 AM
Yikes, sounds like a call to grizzly could be in order. I’m not sure how a mag switch could break in such a way to remain on, but I’m not an electrical engineer.
Seems like even with mag switches we should pull the plugs when the power goes out.
View ste6168's profile
ste6168
252 posts in 1041 days
#5 posted 02-13-2016 12:22 PM
Yikes, sounds like a call to grizzly could be in order. I m not sure how a mag switch could break in such a way to remain on, but I m not an electrical engineer.
- BonPacific
I don’t think it was a switch failure, rather operator error because he was under the assumption a mag-switch was installed. Not even certain you could refer to that as operator error? My grizzly hyrbrid does not have a mag-switch. Which model do you have, 716?
View hotbyte's profile
hotbyte
989 posts in 2845 days
#6 posted 02-13-2016 12:43 PM
Regardless of how switch should operate, why not turn switch off when leaving the shop? Or, even immediately when power went off.
4820 posts in 2363 days
#7 posted 02-13-2016 01:15 PM
That’s either not a magnetic switch (despite the manual references) or it’s defective. Replacing it with a regular one is easy to save money (for Grizzly), and they may have chose (or forgot) to update the manual.
View Nubsnstubs's profile
Nubsnstubs
1223 posts in 1600 days
#8 posted 02-13-2016 01:17 PM
Hotbyte, if your machines are hardwired, you can’t unplug them. But, there is always that good old forgotten breaker panel, and turn off the breaker…........ Jerry (in Tucson)
hotbyte
#9 posted 02-13-2016 01:27 PM
Didn’t say unplug…I said turn off switch. From posts, it reads like he was using saw and power went out. He left shop with switch in On position assuming it was a mag switch and would not turn on if power was restored.
Hotbyte, if your machines are hardwired, you can t unplug them. But, there is always that good old forgotten breaker panel, and turn off the breaker…........ Jerry (in Tucson)
- Nubsnstubs
View MrUnix's profile
MrUnix
6186 posts in 2069 days
#10 posted 02-13-2016 07:15 PM
The manual talks about a mag starter box that gets installed on the back of the saw, yet the pictures from Grizzly don’t show one… and the manual says the switch type is just an on/off push button type in the specifications, yet calls it a mag switch later on. Parts diagram for the saw shows a simple on/off switch w/paddle and a breaker that can be changed for either 120 or 240v operation. Seems like the manual was edited from previous/other models and isn’t entirely accurate. Doubt that’s a mag switch.
View ThomasChippendale's profile
ThomasChippendale
244 posts in 802 days
#11 posted 02-13-2016 08:27 PM
Its easy to find out, disconnect your machine while it is running and plug it back, it should not start again with a magnetic switch.
-- PJ
TopamaxSurvivor
18159 posts in 3546 days
#12 posted 02-14-2016 02:36 AM
If the magnetic motor starter is wired with momentary on/off buttons, it will stay off when power is lost. If a magnetic motor starter is wired to a maintained on/off switch, it will turn on when power is restored if the switch is on. Your saw has a maintained switch in the circuit if it started when the power was restored. No ands, ifs, or buts about it. Motor control 101.
View 716's profile
716
#13 posted 02-17-2016 06:51 PM
Yest, most probably it was copy/paste mishap by someone who wrote the manual. I asked Grizzly about it and got quite an unexpected answer. They want to send me a new switch :-).
Too tempting to get it, moreover I need one for the router table, but my conscience would eat me alive every time I turn on the router then. I think I will pass.
-- It's nice!
View ohtimberwolf's profile
ohtimberwolf
736 posts in 2222 days
#14 posted 02-18-2016 01:30 AM
716, wise choice…
-- Just a barn cat, now gone to cat heaven.
