breadboard ends on plywood top
« back to Joinery forum
Forum topic by StDane posted 02-12-2016 10:26 PM 1264 views 0 times favorited 3 replies Add to Favorites Watch
View StDane's profile
StDane
7 posts in 1070 days
02-12-2016 10:26 PM
I am wanting to make a table top with veneered plywood surrounded on all four sides by a 4” band of maple. Do I need to do the full breadboard treatment with plywood, as in mortise/tenon/pegs for the ends. Can I just glue them up (probably with biscuits)? Should probably not glue the intersections of the end and side boards. Otherwise, what have folks done tried, along these lines?
The attached photo is what I want to replicate. The center in photo is a single piece of walnut, so obviously I did the full treatment. Subsequent tops will be plywood/veneer for a figured finish.
3 replies so far
View bondogaposis's profile
bondogaposis
5149 posts in 2587 days
#1 posted 02-12-2016 10:32 PM
Yes, plywood is stable you can just glue it up.
-- Bondo Gaposis
View rwe2156's profile
rwe2156
3230 posts in 1716 days
#2 posted 02-13-2016 12:54 PM
Edge gluing a breadboard end to plywood is not going to be strong enough for a table in the long run.
Unless you want the look you don’t need pins you can glue the whole tenon no movement issues with ply.
StDane
#3 posted 02-13-2016 02:59 PM
So you’re saying make a tenon, but glue it all up-don’t worry about movement? That actually seems sensible.Would biscuits do okay. I have not used them much, do they impart a little more strength, or do they just help keep things lined up?
