The best way to cut a 2 x 4 diagonally?
Forum topic by namrufmot posted 02-12-2016 09:49 PM 1614 views 0 times favorited 24 replies Add to Favorites Watch
View namrufmot's profile
namrufmot
54 posts in 987 days
02-12-2016 09:49 PM
I need to cut a 2×4 diag for a wheelbarrow…I could jig or circular saw but that’d be a little sloppy…what’s the best way? Tapering jig in the table saw?
24 replies so far
View derrickparks57's profile
derrickparks57
129 posts in 1991 days
#1 posted 02-12-2016 10:05 PM
Tapering jig is probably the best way.
-- Derrick, Florida, DP Woodwerks
Smitty_Cabinetshop
15519 posts in 2738 days
#2 posted 02-12-2016 10:15 PM
Bandsaw, cleaned up with a hand plane is what I’d probably do.
View waho6o9's profile
waho6o9
8362 posts in 2696 days
#3 posted 02-12-2016 10:31 PM
Track saw
namrufmot
#4 posted 02-12-2016 10:37 PM
Don’t have a track saw…could use a circular saw with a guide? Or the tapering his I guess..
Thanks guys
View bbasiaga's profile
bbasiaga
1240 posts in 2115 days
#5 posted 02-12-2016 11:29 PM
I have done this with my circular saw before. Is it going to show when you are done? Or does it just need to be close? The circular saw method can get a little rough, though a guide helps.
-Brian
View Jim Finn's profile
Jim Finn
2670 posts in 3041 days
#6 posted 02-13-2016 12:20 AM
I would use my table saw, sliding, taper sled to make this cut.
-- No PHD just a DD214 Website> craftingcouple.com
Smitty_Cabinetshop
#7 posted 02-13-2016 12:39 AM
Okay, what tools do you have, that you’re willing to use? The suspense is killing me.
namrufmot
#8 posted 02-13-2016 01:26 AM
Table saw, band saw, jig saw, miter saw, circular saw….ill buy a jig if I have to lol
View BurlyBob's profile
BurlyBob
5897 posts in 2385 days
#9 posted 02-13-2016 01:58 AM
Go cheap and easy. Draw the line you want, set between two other 2x’s and carefully cut the line. The other 2x’s will support the baseplate of your circular saw. When your don clean it up with a hand plane. It works I’ve done it a few times. It’s for a wheelbarrow. Like a mentor preached to me, “you ain’t building a piano”.
TopamaxSurvivor
18358 posts in 3795 days
#10 posted 02-13-2016 01:59 AM
You could jig the 2×4 with another straight 2×4 screwed to it.
117203 posts in 3697 days
#11 posted 02-13-2016 02:17 AM
Like others have said use a taper jig.
Smitty_Cabinetshop
#12 posted 02-13-2016 10:11 PM
^ if I could build that jig, I wouldn’t ask how to make a taper cut. Wow, that’s a project in itself.
#13 posted 02-13-2016 10:27 PM
The taper sled is not really too tough to build.
Smitty_Cabinetshop
#14 posted 02-13-2016 10:40 PM
I’m just not a jig guy, I guess. I’m sure it’s great for repetitive cuts of all kinds.
#15 posted 02-13-2016 10:44 PM
Hey Smitty we all do things the way they work for us,there’s almost always another way to do things in woodworking.
