Fixing a crack(s)
« back to Woodturning forum
Forum topic by Mark posted 02-12-2016 01:05 AM 804 views 0 times favorited 11 replies Add to Favorites Watch
View Mark's profile
Mark
878 posts in 1882 days
02-12-2016 01:05 AM
Afternoon all. I was turning a vessel this afternoon and was darn near done, so just to break the monotony I had to catch an edge. So now I have 2 large and long cracks in the vessel. It has excellent grain and swirls so I want to save it. The plan is to accent the cracks with copper fillings. Should I: a) Mix up a batch (for each crack) of epoxy & fillings. Fill and clam? b) Glue and clamp the cracks with epoxy first. Then using a fine bit on the dermal, score the now sealed crack, add the fillings and cover with CA glue? In option “b” could I use CA glue instead of epoxy?
Thank you
-- Mark
11 replies so far
View Bob Collins's profile
Bob Collins
2486 posts in 3591 days
#1 posted 02-12-2016 01:30 AM
Mark, would you need filling in those thin cracks, if you can get a tight enough clamp on the vessel tightbond glue should do the trick, give it 24 hours to cure and do a fine sanding. If you are not happy then score the marks and fill with copper and CA glue. I can see why you want to save it, nice grain. Definitely a epoxy job for the side if you are going to fill. Lets see the results.
-- Bob C, Australia. Your best teacher is your last mistake.
View Mark's profile
Mark
#2 posted 02-12-2016 04:01 AM
Thanks for the advise Bob. No that big ass hole on the side stays. I’m going to have to chuck it up and re turn the top. The cracks won’t line up I don’t think. The insides down to 3/8” thick…could come down another 1/8. But I’m scared!!!
-- Mark
View JBrow's profile
JBrow
1327 posts in 828 days
#3 posted 02-12-2016 04:15 AM
Mark,
It is a beautiful turning job and the wood is quite nice. I do not envy you the challenge of fixing these cracks.
If the vessel cracked because of stresses in the wood, re-gluing could lead to failure elsewhere since gluing could reintroduce the stresses. Even if the vessel hit the floor and the cracks appeared, it could still have resulted from internal stresses (I am not sure what “had to catch an edge” meant).
This is obviously a difficult piece to clamp. If you were to clamp, I suppose a band clamp at the widest point of the vessel might close the gap all along the vessel. Alternatively, a pair of semi-circular cauls could be used at the rim, but I am not sure to what effect on such a complex piece. Perhaps a little downward pressure from the small opening of the vessel would keep the upper (small mouth opening end) from opening up under clamping pressure.
One method I have used with some success to fix a straight crack on a flat surface is to first rip thin “filler” wedges (although accurately cut square filler strips also work). Then I made a through cut centered in the crack. Glue was applied to both sides of the wedge and inserted into the cut-open crack until snug – no clamps. In this case, multiple wedges may be required and perhaps would have to be introduced on both the inside and outside of the vessel. When the glue cures, the wedges are flushed-up with a chisel and sand paper.
However, in this case, I am not sure how well the wedge filling would work. The major and minor cracks have significant curves (not straight lines). Also, it is difficult to image that if successful with this fix even with the same wood as the turning, that it would not draw attention away from the beauty of the vessel to the fix. But I thought I would mention this method anyway.
Another idea similar to the “wedge” idea, since you are thinking of adding copper, would be to get thin copper, open the crack, maybe at the bandsaw, and epoxy the copper directly in place. The thin copper could make the bends required as a single continuous ribbon. The copper would have to be thin in order to flush it up but thick enough to bridge the gap. Flushing up the copper could be done probably using sandpaper. If the copper is cut in the profile of the turning before gluing in place, it would reduce the work of flushing up the cooper to the vessel. Also this method would require an epoxy that could accommodate the expansion and contraction of the copper. The significant advantage of this approach is that it keeps the Dremel out of your hands. If you are like me, accurately routing a space for the copper fill would be a challenge and I know if it were me behind the Dremel, I would just make bad matters worse.
I am not sure I helped any, but that is all I got. Good luck!
View Nubsnstubs's profile
Nubsnstubs
1249 posts in 1638 days
#4 posted 02-12-2016 02:21 PM
You got your catch, so, did your vessel take flight? I ask because you didn’t say how it was held.
The suggestions you’ve gotten so far are good enough for me If that was my problem. I couldn’t add any new ones if I tried.
The wood is a keeper, so explore all the options before continuing… What wood is it? Looks a little like mesquite crotch wood, but could be any crotch wood…... ........... Jerry (in Tucson)
View Mark's profile
Mark
#5 posted 02-12-2016 04:50 PM
Thanks for your detailed responce JB. It was basically a catch that did it. The piece was chucked up and did not fly when it bit. Ya glue up should be interesting.
Jerrry. I’m not sure what it is. Friend of a friend had had it for years. It was a large piece 8” sq x 25” L. I’m thinking’ Cherry
-- Mark
Bob Collins
#6 posted 02-13-2016 02:57 AM
Mark, have a look at Ronald Campbell’s pages on LJ’s and see how he uses resin on his projects. His latest project points you to where he gets it. Might be handy in the future.
View BurlyBob's profile
BurlyBob
5250 posts in 2173 days
#7 posted 02-13-2016 03:20 AM
That had to be a real heartbreaker!
View Mark's profile
Mark
#8 posted 02-13-2016 11:19 PM
Thanks for the link Bob. Mr. Campbell does some amazing work.
-- Mark
View Roger's profile
Roger
20904 posts in 2712 days
#9 posted 02-14-2016 04:43 PM
My guess would be to mix the filings with the epoxy. If you can get something in the crack to open it up ever so slightly without cracking it worse, then push/squeeze the mixture into the cracks the best you can, and gently clamp it. (gently) After they’re dry, sand em and see if you need any other filler. Just my thoughts
View NJJoe's profile
NJJoe
7 posts in 1046 days
#10 posted 02-15-2016 06:35 PM
Mark, an alterantive is to get some key dust from HD or Lowes, mix it with epoxy and than fill the crack. Under their key-cutting machines there will be a small dust collector which will have all the brass-colored dust you will ever need. Mixed with clear epoxy it gives a very nice textured metal look
View OSU55's profile
OSU55
1523 posts in 1897 days
#11 posted 02-15-2016 09:25 PM
Curious to learn more about the catch. Where were you turning on the piece, type of tool, etc.
