| Forum topic by davidroberts | posted 1197 days ago | 1183 views | 0 times favorited | 4 replies | ![]() |
1197 days ago |
I have removed the lower guide assembly from my old 14” Delta bandsaw and proceeded to clean up that mess of rust, goo and glop. The lower thrust bearing is shot and I want to replace it. I could soak the whole thing in WD 40 to see if it will spin better, but probably not. So here’s a real simple question. How do I remove the bearing from the rod? Does anyone know of a simple method, without me having to buy a bearing puller. I have a couple of ideas but wanted some input from folks that have surmounted this challange. Thanks for your consideration. -- david roberts, spinning Tales from Topographic Oceans, no, really. |
