| Forum topic by JNelson | posted 1194 days ago | 2196 views | 0 times favorited | 13 replies | ![]() |
1194 days ago |
I was about to pull the trigger on the Rockler sale on the 8” Oshlun dado blade kit for $60.00 but remembered someone saying some saws do not have the power for an 8”. The table saw in question is the Ridgid R4511 granite table saw. It supposed to have a 1&1/2 horsepower motor. Would I be better off with the 6” instead? I just hate to buy the 6” when the 8” is cheaper, but ultimately wan’t the one that will perform better. I only plan to use it for building shelves, built-ins, cabinets etc and don’t think I would ever need a cut that was deeper than 3/4”. Any input or opinions would be greatly appreciated |
13 replies so far
#1 posted 1194 days ago |
I’m pretty sure it can handle an 8”, but considering the sudden proliferation of 4511s due to the sale that I missed out on cries briefly in the corner I’m sure one of other lucky LJs that scored one cries a little more has some first hand experience -- - Jei, Rockford IL - When in doubt, spray it with WD-40 and wrap it with duct tape. The details will attend to themselves. |
#2 posted 1194 days ago |
Not sure what the Rockler sale on the 8” model is, but I got my 6” Oshlun last year for $45.00 at Rockler… VERY happy with it… -- Manufacturer of fine quality sawdust since 1984. Comments and advice on my shop welcome. Check it out at http://lumberjocks.com/dbhost/workshop. Gladly accepting shop build donations! |
#3 posted 1194 days ago |
Right now the 6” are $70, and the 8” are $60 -- - Jei, Rockford IL - When in doubt, spray it with WD-40 and wrap it with duct tape. The details will attend to themselves. |
#4 posted 1194 days ago |
mine runs a 8” perfectly fine |
#5 posted 1194 days ago |
I’ve been running 8” Freud with nearly a full stack at times. Worked just fine – go with the 8. |
#6 posted 1194 days ago |
The 8” offers more cutting depth (and more teeth) ....the extra depth isn’t needed often, but if you ever use a sled, the extra depth would be handy. Your saw should spin the 8” fine. -- Happiness is like wetting your pants...everyone can see it, but only you can feel the warmth.... |
#7 posted 1194 days ago |
What? Not enough power to power an 8” blade? Someone step in and correct me if I’m wrong but I would be SHOCKED. I’ve got a Delta contractor saw- probably also 1.5 hp. Very comparible machine I would think. No problems with 8” blades. |
#8 posted 1194 days ago |
Check the manual on your saw. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#9 posted 1194 days ago |
I checked my manual and it doesn’t say anything about what size to use, I have the same saw. |
#10 posted 1194 days ago |
Thanks for all of the replies. I am going to get the 8”. Lots of good reviews, more teeth than the 6” on the chippers, and cheaper. I don’t see how I can go wrong. Cliffton, your review of the blade was what led me to looking at Oshlun! Did your saw fall under the arbor shaft recall? I just had mine done and they replaced the shaft so hopefully no flying dado blades will be in my future! Thanks again for all the feedback |
#11 posted 1194 days ago |
I have an 8” Systi-Matic dado set that ran just fine on my old 1HP Craftsman TS, and even better on my 1.5HP Jet. -- Adversity doesn't build character...................it reveals it. |
#12 posted 1193 days ago |
Nope mine wasn’t one of the recall ones, though when i fired it up and raised it through the ZCI I did stand to the side :D |
#13 posted 1193 days ago |
Go for 8”. I have the 3660 and has never had issue using full stack 3/4 dado. If you ever use a sled, you will need 8”. if not then 6” will do. -- Router รจ ancora il mio nome. |
| Forum | Topics |
Woodworking Skill Share
8791 |
Woodturning
221 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1530 |
3547 |
15769 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
