Adding Color in Epoxy
Forum topic by moke posted 02-11-2016 06:15 PM 1355 views 0 times favorited 11 replies Add to Favorites Watch
View moke's profile
moke
1179 posts in 2798 days
02-11-2016 06:15 PM
I noted in one of my woodworking online magazines that enamel and epoxy glues are not a good mix….they advised to use a colored powder. I have mixing a couple of drops of the Testor’s enamel (model paint) to a small amount of 5 minute epoxy for years with what I thought was decent results….I have had failures but not often…maybe 1 out of 30 times…
I would mix the recommended colored powder, and just write it off as me being wrong, but I use white about 90%
of the time, and it appears as the powdered colors don’t come in white.
Anybody have any suggestions or thoughts?
Mike
-- Mike
11 replies so far
View Snowbeast's profile
Snowbeast
82 posts in 1360 days
#1 posted 02-11-2016 06:20 PM
You might try artist type oil paint. I use a black paint from a tube in two-part epoxy and have never had an issue.
Just be aware. A VERY small amount goes a long way with this.
Good luck with it.
View AZWoody's profile
AZWoody
1346 posts in 1246 days
#2 posted 02-11-2016 06:40 PM
I use transtint dyes. 1 or 2 drops will go a long way.
View Ger21's profile
Ger21
1074 posts in 3153 days
#3 posted 02-11-2016 06:50 PM
View MrUnix's profile
MrUnix
6757 posts in 2221 days
#4 posted 02-11-2016 06:54 PM
I use dry power pigments and have never had any kind of failure… but I’ve never done a white – usually the darker ranges such as reds, tans, browns and blacks (depending on the wood and contrast I’m looking for) The stuff they sell for coloring cement at the BORG works great btw :) You can get dry pigments at a hobby store that sells oil painting stuff (for mixing your own colors) in a wide range of colors. You may find this article at West Systems interesting, as they test various pigments and dyes in conjunction with their epoxy.
West Systems - Adding pigments to epoxy
View ClammyBallz's profile
ClammyBallz
435 posts in 1158 days
#5 posted 02-11-2016 08:03 PM
View bigblockyeti's profile
bigblockyeti
5134 posts in 1742 days
#6 posted 02-11-2016 09:11 PM
I’ve heard of using RIT dye and liked the idea as it’s cheap and should last a very long time. I’m always looking for a dark blue or black and the ink from a cheap pen works surprisingly well. Getting just the right ratio (especially with 5 minute epoxy) is trick as you don’t have alot of experimentation time as it’s setting. The price can’t be beat!
View rick1955's profile
rick1955
264 posts in 1453 days
#7 posted 02-11-2016 10:00 PM
Go to the System Three or West Systems web site. They make epoxy and have extensive testing on the subject. You can download a manual.
-- Working smarter with less tools is a true crafts person...
View Jim Finn's profile
Jim Finn
2657 posts in 2944 days
#8 posted 02-12-2016 12:10 AM
I have used blue chalk mixed with epoxy with good results. I do not see why white chalk would not also work well.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View Dabcan's profile
Dabcan
255 posts in 2693 days
#9 posted 02-12-2016 03:45 AM
I did this with latex paint a few weeks back. A few drops of yellow paint tinted the epoxy nicely and it hardened normally, it was a small fill so I only used 5 minute and not west system.
-- @craftcollectif , http://www.craftcollective.ca, https://www.etsy.com/shop/craftcollective?
View moke's profile
moke
#10 posted 02-12-2016 05:42 PM
Thank you one and all…some great suggestions….I have ordered some white pigment tint from US Compsites…it’s cheap and specifically meant for Epoxy resins….but I am going to try some simple white chaulk….( I hope my granddaughter doesn’t notice some missing from her sidewalk chalks!!!)
Thanks again,
Mike
-- Mike
View rtbrmb's profile
rtbrmb
630 posts in 2410 days
#11 posted 02-12-2016 08:04 PM
This is an interesting topic-I try to color epoxy on many of my projects.
Please keep us posted on the results from the white pigment & chalk.
Bill in MI
