High Angle Frog
Forum topic by Marc5 posted 02-12-2010 04:06 AM 1927 views 0 times favorited 6 replies Add to Favorites Watch
View Marc5's profile
Marc5
304 posts in 3370 days
02-12-2010 04:06 AM
I have some Ash that I have planed down with my hand planes. I have it very close to the finished thickness and have 3 areas where I can’t seam to prevent the tear out. I have reversed direction attempting to resolve the issue but the tear out is only moved further down the board. I realize scrapers are an option but I don’t think the digits could handle it these days. I have read that using high angle frogs help but in looking the LN site there is 2 of them; one 50 degrees and the other @ 55. I only want to by one of these and I am looking for a littel advise on which to buy. I am hoping the 50 degree is the one in order to keep the workout down a bit.
Any suggestions or comments will be greatly appreciated.
-- Marc
View bigike's profile
bigike
4052 posts in 3316 days
#1 posted 02-12-2010 04:16 AM
what about using a #80 cabinet scraper or a scraper plane like a #112? i would go the 50 deg. way if i were buying a new frog. You can also regrind the blade/blades in your plane to give this angle but the math i don’t know, sorry. Also u can try to wax the plane sole with parrafin wax and this makes it easy to push across the wood.
View WayneC's profile
WayneC
13754 posts in 4125 days
#2 posted 02-12-2010 04:16 AM
Check out this article by Chris Schwartz. He contrasts the two…..
http://www.popularwoodworking.com/article/Endurance_Test3/?print=1
Marc5
#3 posted 02-12-2010 12:52 PM
The Schwartz article was helpful. I am going to see if I can pick up a 80 scraper on ebay and give it a shot before purchasing a high angle frog. Thanks for your response, it is very helpful.
-- Marc
WayneC
#4 posted 02-13-2010 06:35 AM
You might also look for a Stanley 112. There was quite a bit of discussion on scraper planes a bit back…
http://lumberjocks.com/projects/24141
http://lumberjocks.com/topics/12052
View MattH's profile
MattH
27 posts in 3666 days
#5 posted 02-13-2010 07:05 AM
You might also simply try a hand scraper, the plain piece of sharp metal – get it good and sharp, with a strong burr, and then use it. if you have gloves with grippy fingers, it’ll work better and your fingers won’t get burnt from the heat it generates. Your hands will get stronger and the work will be BEAUTIFUL. It’s not at all hard to learn and it leaves a wonderful surface.
-- Death before dishonour; nothing before coffee
Marc5
#6 posted 02-16-2010 03:05 AM
I found a #80 and it is doing the job. I honed the blade with a 4000 grit stone foregoing the 8000 girt and was getting very fine shavings. I am guessing using the 8000 grit stone may help but not sure. Nevertheless the damage is gone and honestly looks pretty good. This is my first time using a scraper plane and was wondering if there is any benefit to striking a burr on the blade?
-- Marc
