Is 1/2" bore shaper really only good for router bits?
Forum topic by CraiginSTL posted 02-11-2016 04:45 PM 1991 views 0 times favorited 11 replies Add to Favorites Watch
View CraiginSTL's profile
CraiginSTL
9 posts in 799 days
02-11-2016 04:45 PM
Topic tags/keywords: shaper raised panel doors
Hadn’t done any research when the opportunity to buy a used Grizzly 1/2” bore shaper (G510z) came up and I jumped at it. Heard shapers were the way to go with things like rails, stiles, raised panels.
So now I see Grizzly doesn’t even sell 1/2” bore cutters to use on raised panel doors.
And the Grizzly rep said that shaper is pretty much only good for running 1/2” router bit sets for raised panel doors.
Is that really true? Is anyone using 1/2” bore shaper cutters for these doors – and if so where do you get them?
Thanks,
Craig
11 replies so far
View HokieKen's profile
HokieKen
4734 posts in 1101 days
#1 posted 02-11-2016 05:27 PM
A quick look on MLCS site shows several raised panel shaper cutters with 3/4” bores that come with 1/2” bushings.
-- Kenny, SW VA, Go Hokies!!!
CraiginSTL
9 posts in 799 days
#2 posted 02-11-2016 05:42 PM
Thanks Kenny
But doesn’t putting a 3/4” cutter on a 1/2” shaper spindle kind of feel like fitting a 1/2” router bit into a 1/4” collet? I hope someone who has experience in doing this speaks up so I can get on the bandwagon.
View Andre's profile
Andre
1775 posts in 1769 days
#3 posted 02-11-2016 05:45 PM
Not sure I have the 1035, it comes with the 3/4” spindle and a collet adapter for router bits?
4945 posts in 2456 days
#4 posted 02-11-2016 07:03 PM
Thanks Kenny
But doesn t putting a 3/4” cutter on a 1/2” shaper spindle kind of feel like fitting a 1/2” router bit into a 1/4” collet? I hope someone who has experience in doing this speaks up so I can get on the bandwagon.
- CraiginSTL
- HokieKen
The bushings should make it work just as a 1/2” to 1/4” sleeve adapter wouod in your router bit example.
CraiginSTL
9 posts in 799 days
#5 posted 02-11-2016 07:14 PM
Thanks Ken I do get what you’re saying however if I bought a little router that wasn’t supposed to take anything bigger than a quarter inch bit something just tells me it wouldn’t be a good idea to find a three quarter to quarter inch adapter and run half inch bits. But maybe I’m just looking at it wrong
HokieKen
#6 posted 02-11-2016 07:39 PM
Thanks Ken I do get what you re saying however if I bought a little router that wasn t supposed to take anything bigger than a quarter inch bit something just tells me it wouldn t be a good idea to find a three quarter to quarter inch adapter and run half inch bits. But maybe I m just looking at it wrong
- CraiginSTL
Don’t get me wrong, I wasn’t advocating one way or another, I was just giving you a suggestion on where to get cutters. I don’t own, nor do anything that requires, a shaper. I have a 3-1/4 hp router that does everything I need it to. As a machinist though, I can tell you that the bore size in the cutter will have little affect on the performance as long as it’s a quality cutter with a precise bushing/adapter. The spindle size provides your stability/rigidity. As long as the cutter isn’t too big for the speed and hp of your motor, I don’t think you’ll have any problems.
View teejk02's profile
teejk02
481 posts in 1088 days
#7 posted 02-11-2016 07:56 PM
1/2” spindles were sold for the home workshop for years. I’ve been told that they will accept 3/4” cutters with a bushing. I bought a vintage Rockwell years ago and keep meaning to try it out. The fence is massive (and split). The motor switch has a forward/reverse thing. The cutter itself moves up/down easily. Thinking about getting a few cutters for round over work…maybe some ogee work too. Probably requires a few passes on hardwood but no different from a router in that respect is it?
View AlaskaGuy's profile
AlaskaGuy
4041 posts in 2272 days
#8 posted 02-11-2016 09:37 PM
runswithscissors
2724 posts in 1988 days
#9 posted 02-14-2016 10:28 PM
I had one of those, but never got much use out of it. That’s a pretty light duty shaper for large cutters. They do work fine with router bits, though some would say the rpms aren’t high enough. One problem with them is that they give you very little adjustment range vertically—only about 7/8” I think.
After that shaper, I went with a big router in a table for a while, then back to shapers, first Grizzly 1.5 horse model, then to a Jet 2 hp that I like very much (both from CL, naturally). I do use router bits in mine quite often, and find the results satisfactory. Two h.p. with an induction motor, vs 3.5 from a router’s universal motor, is like comparing a clydesdale to a shetland pony. Both the larger shapers had bigger spindles, more appropriate to large cutters.
View 808bob's profile
808bob
1 post in 754 days
#10 posted 04-05-2016 06:13 AM
I have a Rockwell 1/2” shaper and use it for moldings, picture frames and joinery. The shaper is quieter and reduces a lot of the vibration (cast iron table) that a router table would have. It can’t do all that a router mounted under a table can do, but for certain jobs I have a router. I feel that both have their purpose in my shop. Try the shaper, I don’t think you’ll be disappointed.
-- Bob
View SirIrb's profile
SirIrb
1239 posts in 1193 days
#11 posted 04-05-2016 11:23 AM
The bigger the spindle the better you are but dont look at the green bear as the only supplier for cutters. Also you can reduce 3/4 cutters to 1/2. You also may be able to swap the spindle to 3/4.
Shapers are great and there is no other way to go. You can run bits on them but that is like saying you can sit in your car in the driveway and listen to the radio. Sure you can but you can drive it at high speeds down the highway and listen to the radio too. I ll take the high speeds w/ radio.
