Dado Blades
Forum topic by Novice1231 posted 02-12-2010 01:51 AM 2537 views 0 times favorited 8 replies Add to Favorites Watch
View Novice1231's profile
Novice1231
5 posts in 2998 days
02-12-2010 01:51 AM
Hello, Please excuse my ignorance, I just recently decided I want to take up woodworking. I have a 10” (Pro-Tech) tablesaw. Do I need to buy a 10” dado set? Or will an 8” set work on my tablesaw? Any advise will be appreciated.
8 replies so far
View Jeison's profile
Jeison
968 posts in 3075 days
#1 posted 02-12-2010 02:01 AM
dado sets come in 6” or 8” sizes, usually a 6” set is more than enough for most dado operations, an 8” is usually only necessary for very deep grooves. Also less powerful tablesaws may struggle with the extra mass of the 8” set, especially for wide dados.
Rockler sells the Oshlun 6” set (which has gotten lots of great reviews) for about $70, although if you have a more powerful saw and go the 8” route their 8” stack is on sale for $60.
-- - Jei, Rockford IL - When in doubt, spray it with WD-40 and wrap it with duct tape. The details will attend to themselves.
View dryhter's profile
dryhter
74 posts in 3571 days
#2 posted 02-12-2010 02:11 AM
Hey Novice,
I just posted this LINK
If you are interested.
-- Chips and Shavings/ see you at WWW.underconstructionlive.com
117063 posts in 3545 days
#3 posted 02-12-2010 02:13 AM
Your saw won’t take a dado blade if it’s the kind of 10 ” Protech that has a direct drive. If your could put one on it won’t be safe. Sorry about that.
View RKW's profile
RKW
328 posts in 3415 days
#4 posted 02-12-2010 02:57 AM
Im not familiar with your table saw, but like jim said, it may not take a dado. The first table saw i had would not. One thing to keep in mind, the quality of blade makes a huge difference. I now have two dado sets, one is a cheap harbour freight set which is great for mdf, the other is a freud set. The later set cost three times as much, but produces very little if any tear out. Good luck
-- RKWoods
View RKW's profile
RKW
#5 posted 02-12-2010 03:00 AM
oh yeah, i didnt even answer your question. 8” should be fine. (if your saw will take it) The arbour was not long enuff on my first saw. I could only fit the two blades and one chipper on it.
-- RKWoods
View knotscott's profile
knotscott
7980 posts in 3343 days
#6 posted 02-12-2010 03:47 AM
If your saw isn’t up to the task of spinning a stacked dado set, a router with a straight bit can also do a good job….the bits are usually a lot less than a dado set, and a router is just plain handy to have if you don’t already own one.
View iamwelty's profile
iamwelty
259 posts in 3083 days
#7 posted 02-12-2010 03:55 AM
I’m betting the arbor isn’t long enough and the saw doesn’t have the umph tp handle any dado set… Once again, Jim is right on… It is my understanding that the Protech’s are extremely light duty saws.
-- There is a fine line between eroticism and nausea...
View SnowyRiver's profile
SnowyRiver
51457 posts in 3448 days
#8 posted 02-12-2010 05:41 AM
I am not familiar with the Protech table saw, but if it will take a dado blade, you could try a short arbor dado blade. They work quite well. I use one on my bench top Delta saw when on a job site and it cuts very well even though the saw has a very small motor.
-- Wayne - Plymouth MN
