Drill press problems
Forum topic by Dukebball7 posted 02-11-2016 02:50 AM 539 views 0 times favorited 10 replies Add to Favorites Watch
View Dukebball7's profile
Dukebball7
2 posts in 922 days
02-11-2016 02:50 AM
Topic tags/keywords: drill press problems
Hi all I am new to this but I need help. I have a 10 in harbor freight drill press that I have had for about 1 month now. With little bits that I have used, 1/4 up to 3/8, the drill press has been flawless. But I tried a 3-1/2 in Forstner bit on the lowest speed at 300 rpm and when I BARELY put pressure down to go into the wood the bit stops. I have opened the top and it has a 3 pulley system for 12 different speeds. The furthest pulley keeps running since it is connected to the motor, the middle pulley that connects the two keeps turning, but the pulley closest to the chuck stops spinning and so does the belt thus the chuck and bit stop. I have read that to tighten the set screw on one of the pulley and it is tight. Still new belts since I just got it a month ago. Please help. Thanks.
10 replies so far
View TheWoodRaccoon's profile
TheWoodRaccoon
364 posts in 1015 days
#1 posted 02-11-2016 03:12 AM
A 3 1/2 inch forstner bit is asking a lot from your little 10” drill press. It sounds like the front belt is slipping, as it’s not under enough tension.
You should set it on the slowest speed, and don’t put as much downward pressure on the bit. Tighten the belts so they feel taught, but only just so. Also make sure your bit is sharp, and try again.
-- still trying to think of a clever signature......
Dukebball7
2 posts in 922 days
#2 posted 02-11-2016 03:15 AM
It is on the lowest speeds at 300 rpm, I am BARELY pushing down, like one finger pressure, the belts are as tight as they go, and they are brand new bits.
View MadMark's profile
MadMark
979 posts in 1539 days
#3 posted 02-11-2016 03:22 AM
Too much bit, too little drill press.
Most forstners have an edge cutter and a chipper. The chipper will tend to dig in when parallel to the grain. Is your cutter carbide?
I have the same size cutter and i found i had to bounce it thru the cut. Tap down until bind, release and repeat.
M
View bandit571's profile
bandit571
20742 posts in 2769 days
#4 posted 02-11-2016 03:47 AM
The 5 speed one I got awhile back from H-F, the front pulley ( of the two) did not even have a set screw installed.
$0.49 + tax to fix. It will stall out, but I also run the Forstner bits at full speed. One finger feed.
Might look inside the hole where the screw is supposed to be….
TheWoodRaccoon
#5 posted 02-11-2016 04:57 AM
- Dukebball7
Try the highest speed then, with little pressure.
View MrUnix's profile
MrUnix
6848 posts in 2285 days
#6 posted 02-11-2016 05:02 AM
Running a forstner bit too fast will quickly ruin it, and 3.5” is a pretty big hole to ask from that little press (the motor is 3.8A FLA, so what is that, maybe a 1/4hp?). If you are drilling a through hole and the material is not too thick, a hole saw would be a better option.
View 716's profile
716
502 posts in 1002 days
#7 posted 02-11-2016 05:40 AM
Do you have smaller bits ? Try from a small one swapping it for a bigger progressively.
-- It's nice!
View BurlyBob's profile
BurlyBob
5858 posts in 2351 days
#8 posted 02-11-2016 05:55 AM
What Brad and Raccoon said. Remember if your going to a gun fight, take enough gun. Unfortunately you don’t have enough power in your drill press for that job and If you try to slowly run it and let the bit ride you’ll burn it up – scorch the metal and lose all the temper in it. Like Brad said a hole saw might be a better option.
MadMark
#9 posted 02-11-2016 06:18 AM
716, you can’t easily drill progressively with forstners unless you can hold position while you change sizes. A centerless redrill will chatter like hell. It sounds feasable but its not. Now a stepped hole is easy because the centerpoint will automatically recenter on subsequent smaller drills.
M
View 716's profile
716
#10 posted 02-11-2016 06:24 AM
716, you can t easily drill progressively with forstners unless you can hold position while you change sizes. A centerless redrill will chatter like hell. It sounds feasable but its not. Now a stepped hole is easy because the centerpoint will automatically recenter on subsequent smaller drills.
M
- MadMark
I thought we were talking about a drill press not a hand drill, No ?
-- It's nice!
