Adhesives
Forum topic by 67flh posted 02-10-2016 11:43 PM 596 views 0 times favorited 11 replies Add to Favorites Watch
View 67flh's profile
67flh
92 posts in 1515 days
02-10-2016 11:43 PM
Am building a Rocking Horse for my Grandaughter, it has some simple wood adornments that make up the saddle and the bridle. Would liquid nails be suitable for attaching them? Or could you suggest an alternative. Thanks.
-- Brad
11 replies so far
View conifur's profile
conifur
955 posts in 1386 days
#1 posted 02-10-2016 11:46 PM
Need more info and or pics, for me to give an opinion/suggestion.
View 716's profile
716
502 posts in 1151 days
#2 posted 02-10-2016 11:50 PM
I am not sure how your design looks but if you are going to glue wood surface to surface it won’t work in the long term. You wold not want your granddaughter to fall together with the broken off saddle.
Liquid nails like any other glue works reliably in a some kind of a joint, like tenon and mortise for example. In other words liquid nails is a auxiliary not the primary holding force.
-- It's nice!
67flh
#3 posted 02-11-2016 12:20 AM
This is the horse the parts I wish to attach are just for looks and are from 1/8 ” to 3/4” thick the child sits on the body of the rocker and straddles the saddle which is only attached to the sides, the other trim pcs. are up on the head of the rocker and on the rockers. Thanks!!
- conifur
-- Brad
67flh
#4 posted 02-11-2016 12:22 AM
I was using liquid nails as an example as it was all I could think of.
-- Brad
View bondogaposis's profile
bondogaposis
5148 posts in 2585 days
#5 posted 02-11-2016 12:41 AM
I would use Tite Bond II wood glue in that application.
-- Bondo Gaposis
View teejk02's profile
teejk02
489 posts in 1359 days
#6 posted 02-11-2016 12:57 AM
Ran into a great Loctite product a few months ago (goes on white, dries clear). Unfortunately I only see it in the normal caulk tubes…your application would probably require about 5%. Go with wood glue and back up with 18ga brads I guess.
View BurlyBob's profile
BurlyBob
6029 posts in 2500 days
#7 posted 02-11-2016 01:06 AM
I agreed with Bondo. You know adding an upholstery pin might give it a little bling!
View TheFridge's profile
TheFridge
10814 posts in 1720 days
#8 posted 02-11-2016 01:07 AM
Wood glue would be more than enough. Unless it already has a finish on it.
View gfadvm's profile
gfadvm
14940 posts in 2924 days
#9 posted 02-11-2016 01:08 AM
I would use Titebond II like Bondo recommended IF neither glue surface had finish on it.
67flh
#10 posted 02-11-2016 01:16 AM
The main body of the pc. has a poly satin finish on it but the attachments are not finished on their back sides. I plan on using a couple of blind dowels on the saddle part with the glue.
- gfadvm
-- Brad
gfadvm
#11 posted 02-11-2016 01:26 AM
Wood glue (Titebond) will NOT adhere well at all to surfaces with any finish on them. Maybe sand the finish off the area you need to glue? It also will not fill a gap.
