Turning setup for sale
Forum topic by jleiwig posted 02-11-2010 04:24 PM 1342 views 0 times favorited 4 replies Add to Favorites Watch
View jleiwig's profile
jleiwig
47 posts in 3796 days
02-11-2010 04:24 PM
I have a PSI Turncrafter Pro Variable Speed 10×18 wood lathe for sale. I bought it in December. It comes with the following accessories:
2 8” Canton flannel buffs
1 large bar of plastic polish (fine dry grade)
1 large bar of plastic glo polish (ultra fine dry grade)
1 6” grinder
1 10” disc sander
1/2” Steb center
Collet Chuck System
Transfer punch set
5/8” keyless drill chuck with MT2 arbor
3/8” keyless drill chuck no arbor
3 bearing precision ground live center
carbide tipped dead center
precision ground tool steel tool rest system with 3.25” and 6” top bar
3”x4” Micromesh sanding pads
Mini Turning tool set
Center Punch
Vargas Deburr Tool
RCBS chamfer tool
Penturners Drill bit set 7mm, 10mm, 11mm, 27/64”, 3/8”, and letter “O” bits, also 10.5mm , 12.5mm, 15/32, and 25/64 to fit majority of pen kits out there.
150 through 600 grit sandpaper
bottle stopper mandrel and drill bit
specially made bushings for Sierra, Baron, slimline, and cartridge casing pens from www.penturnersproducts.com
5 different plastic storage cases for storing pen kits and bushings
Precision blank cutting jig for CMS.
And a premium assortment of wood/plastic/ and metal pen blanks
Everything you need to start turning pens or anything else you like!. Over $1100 invested as my Christmas present less than 2 months ago. $700 cash or possible trades for a nice tablesaw, jointer, and planer to do some flatwork I need around the house. Let me know what you have I’m open to a lot of trades!
-- I intend to live forever, or die trying..........Justin, Ohio
117117 posts in 3602 days
#1 posted 02-11-2010 05:47 PM
Looks like a good set up, but no room left in my shop.
View Padre's profile
Padre
930 posts in 3514 days
#2 posted 02-12-2010 03:41 AM
A fine set up. I wish I lived closer!!
-- Chip -----------http://www.penmanchip.com-----------------Micah 6:8
jleiwig
#3 posted 02-12-2010 02:57 PM
It is all top quality stuff in my opinion. A lot of people knock the PSI lathe, but I also had a JET 1220 lathe, and the PSI is just as nice as the JET for a little more than half the price!
jleiwig
#4 posted 02-12-2010 05:20 PM
I will also sell the lathe seperately for $180
