Outdoor finish on cypress?
Forum topic by juicegoose posted 02-10-2010 03:20 PM 2562 views 0 times favorited 6 replies Add to Favorites Watch
View juicegoose's profile
juicegoose
117 posts in 3031 days
02-10-2010 03:20 PM
Guys I’m building a couple little butterfly houses for family members(you know how it is you build one and everyone freakin wants one!!). To any extent I had some cypress that i’ve used for the construction and know that cypress is pretty much resistant to weather. I would however like to put at least a little bit of a finish on the piece. What is recommended to use?
View nailbanger2's profile
nailbanger2
1041 posts in 3112 days
#1 posted 02-10-2010 03:23 PM
As many coats of spar urethane as you wish. You are correct, cypress is weather, moisture, and insect resistant.
-- Wish I were Norm's Nephew
juicegoose
#2 posted 02-10-2010 03:43 PM
should I cut the urethane?
27250 posts in 3790 days
#3 posted 02-10-2010 03:45 PM
Ditto on the spar varnish. I put it on our exterior doors which are pine 20 years ago and have had to refinish them only 1 time.
View KnotWright's profile
KnotWright
258 posts in 3457 days
#4 posted 02-10-2010 04:36 PM
I’d do a little research before I put any oil based finish on your butterfly house, if you want them to use it. The finish might keep the butterflys from using it due to the odor / fumes from it when exposed to the sunlight.
I use spar varnish on my cypress Adirondack chairs, but I don’t put any finish on my cypress bird houses, I leave them to weather naturally.
-- James
juicegoose
#5 posted 02-10-2010 04:47 PM
i was afraid of the odor factor thanks
117063 posts in 3546 days
#6 posted 02-10-2010 05:29 PM
I don’t see the need for finish on cypress it will hold up well with out a finish.
