joining oak bar top help
« back to Joinery forum
Forum topic by shastaman posted 02-09-2016 02:22 AM 677 views 0 times favorited 4 replies Add to Favorites Watch
View shastaman's profile
30 posts in 780 days
02-09-2016 02:22 AM
I have two white oak boards that I want to use for a bar top, I currently have the edges within .030” of mating with no clamping and will easily pull together with one clamp. I will be using 1/4” steel brackets to cantilever off my cabinets (yes they are built strong enough), with the bracket screwed to both pieces of oak essentially plating them together do I need to do any more than just glue them together?
They are 1-3/4” x 7-1/2” x 8’
View pintodeluxe's profile
5589 posts in 2744 days
#1 posted 02-09-2016 02:26 AM
Nope, glue is as good as wood itself.
Make sure the dry fit stays flat when all the clamps are on. Use clamps top and bottom every foot or so. Use plenty of glue (I like TB II on white oak).
Good luck with the glueup!
View bondogaposis's profile
4632 posts in 2282 days
#2 posted 02-09-2016 02:46 AM
No, glue alone will be adequate. Clamp it up well. A couple of things to be aware of is that the glue acts a lubricant and things will want to slip and slide a lot more than they do in dry clamping. It will be a challenge to keep the boards aligned without some cauls. Another thing to watch out for is that any ferrous metal that comes in contact with the oak and water will leave a black stain. Glue has enough water to cause this so iron from clamps plus oak plus glue will leave a black stain. The less this happens the easier the clean up.
-- Bondo Gaposis
#3 posted 02-09-2016 03:00 AM
Thanks for both of your replys and the tips. I have since made a few more passes on the jointer and have a no clamp gap of .020” and feel good with that.
OK now for the finish questions, love the raw look but know thats not realistic so satin poly?
Last week I finished my resanded salvaged oak floors with Bona Mega satin and really like the look plus the durability is supposedly outstanding. Its a water based poly.
View waho6o9's profile (online now)
8129 posts in 2507 days
#4 posted 02-09-2016 04:09 AM
I’d use some Dominos or dowels for alignment purposes, other than that
you’re good to go.
