Dado on tablesaw?
Forum topic by westside posted 02-09-2010 11:54 PM 2114 views 0 times favorited 21 replies Add to Favorites Watch
View westside's profile
westside
77 posts in 3351 days
02-09-2010 11:54 PM
I used the search button but could not find the answer. I have a 10” benchtop table saw and was wondering if it can be fitted for a dado blade? I plan on getting a new saw in the future, but for now, this is what I have.
21 replies so far
View lew's profile
lew
12495 posts in 3991 days
#1 posted 02-09-2010 11:56 PM
Probably. The length of the arbor may limit how many blades/chippers can be used.
View Jeison's profile
Jeison
968 posts in 3343 days
#2 posted 02-10-2010 12:02 AM
It can most likely handle up to a 1/2” wide, 6” diameter dado, thats pretty typical for a benchtop i believe
-- - Jei, Rockford IL - When in doubt, spray it with WD-40 and wrap it with duct tape. The details will attend to themselves.
View sphere's profile
sphere
109 posts in 3267 days
#3 posted 02-10-2010 12:08 AM
Maybe a wobbler or Twin cutter. Even if a full stack fit, it may not have the “oomph” to run it ( for long).
-- Spheramid Enterprises Architectural Wood Works
View ,'s profile
2387 posts in 3782 days
#4 posted 02-10-2010 12:09 AM
I started out with a small craftsman we paid 150.00 for brand new. I could get up to 1/2” on it but I would just run 3/8” on it because then I could just make two passes to get a full 3/4” cut. It was serviceable for me at that time and we built some really nice items with that small saw. I look back and realize how dangerous the saw was because of the potential for it to tip over.
Also, we ran a 8” dado blade on our small saw and seemed to do just fine stacked to 3/8”.
View bigike's profile
bigike
4055 posts in 3524 days
#5 posted 02-10-2010 12:16 AM
i had a bench top and i used to put a 8” blade on there it worked good but u can only fit up to 1/2” on there.
View 8iowa's profile
8iowa
1591 posts in 3997 days
#6 posted 02-10-2010 01:01 AM
Table saws designed to run on common household 120V circuits are considered “underpowered” by blade manufacturers. For this type of saw I would recommend a 6” stacked dado set as this will give you more cutting torque. This will become more important as you cut wider and wider dados.
You will also need to find a saw that has a dado table insert available. Otherwise you are limited to the width of the saw blade insert.
View ajosephg's profile
ajosephg
1880 posts in 3797 days
#7 posted 02-10-2010 01:20 AM
I’d seriously consider using a router. You can make a simple jig that makes super accurate dadoes much more safer than you can on an underpowered saw.
-- Joe
View Sawkerf's profile
Sawkerf
1730 posts in 3304 days
#8 posted 02-10-2010 01:20 AM
You want to check this out carefully. Some of the benchtops don’t have arbors long enough to safely accomodate a dado cutter of any type. Two examples are the Craftsman and the small Ryobi (BT30?). My brother has the Craftsman and I have the Ryobi for my jobsite saw. My brother has a little DeWalt wobbler that does an ok job on dados , but is a PITA to get set up right, and won’t do 3/4” dados.
Take the blade out of your saw, run the nut all the way on, and measure the amount of exposed threads left on your arbor. That’s the maximum thickness of your dado cutter – either wobbler or stacked.
westside
#9 posted 02-10-2010 01:26 AM
Thanks everyone for your help. I think a 1/2 inch wide dado would be good enough for now. How do the wobbler dado’s work? Are they any good for cutting dado’s? How are they cost wise compared to a stacked dado? Sorry for so many questions, I know next to nothing about dado blades.
thanks in advance Rich
117417 posts in 3813 days
#10 posted 02-10-2010 01:32 AM
The wobble blade dado blades has a center adjustment that allows you to change the width of the cut ,I think up to 7/8” .The bottom of the dados made by a wobble blade tends to be somewhat rounded compared to a stacked dado. The wobble blades I think start around $59.
View RMH's profile
RMH
16 posts in 3378 days
#11 posted 02-10-2010 01:42 AM
Westside,
I used a wobble dado for a while and was never satisfied with the performance. Jim is correct, the bottom was never flat and getting a precise fit was next to impossible.
-- Ron in central Ohio
View Andrew's profile
Andrew
709 posts in 3434 days
#12 posted 02-10-2010 01:46 AM
Another thing to consider is whether that insert for the table ( that removable thingee that the blade comes through) has enough room, or has a dado insert. Like the guy up there had a craftsman “contractor” ( bench model on a stand) for a couple years and I could do 1/2” dados, occasionally tripped the breaker on the saw. Craftsman has those alot, just meant slower feed rate.
Good luck
-- Even a broken clock is right twice a day, unless, it moves at half speed like ....-As the Saw Turns
sphere
#13 posted 02-10-2010 01:50 AM
Freud makes an adjustable dado that cuts a flat bottom dado, but it’ll lighten the wallet pretty quick.
I think this is it, but it looks pretty fat , arbor wise.
dado
westside
#14 posted 02-10-2010 01:52 AM
After reading all the posts, i think I will stick with the Router. thanks for all the help, I appreciate it.
View miles125's profile
miles125
2180 posts in 4241 days
#15 posted 02-10-2010 02:08 AM
I think lumberjocks voted the wobbler the worst woodwork gimmick of all time a couple years ago :)
-- "The way to make a small fortune in woodworking- start with a large one"
