Use side mount drawers slides as center mounts?
Forum topic by Cory posted 02-09-2010 06:02 PM 3135 views 0 times favorited 7 replies Add to Favorites Watch
View Cory's profile
Cory
760 posts in 3321 days
02-09-2010 06:02 PM
I recently lucked into about 10 pairs of 100lb 18” full extension drawer slides. They’re Accurides about 4 years old but were still in the box. Can I use them as a center mount instead of side mount? Would the compression of the weight of the drawer cause any problems?
Thanks!
Cory
-- The secret to getting ahead is getting started.
7 replies so far
116900 posts in 3478 days
#1 posted 02-09-2010 06:05 PM
I’ve used them that way Cory.
View rhett's profile
rhett
742 posts in 3569 days
#2 posted 02-09-2010 11:06 PM
I have also center mounted them with very good results The application would determine the installation, ofcourse the 100 lb rating is based on a standard application.
-- Doubt kills more dreams than failure.
View ,'s profile
2387 posts in 3448 days
#3 posted 02-10-2010 12:15 AM
This can be done as I have done this for some pull out options in the past but way the glides are built will dictate that by using them this way you will not be able to load them down. As Rhett said, don’t expect them to hold 100 lbs using them in this fashion but for light stuff they would do well as undermounts.
View Sawkerf's profile
Sawkerf
1730 posts in 2970 days
#4 posted 02-10-2010 01:22 AM
I’ve heard that the load rating drops by ~1/2 when they’re mounted that way.
View closetguy's profile
closetguy
744 posts in 3793 days
#5 posted 02-10-2010 02:39 AM
I use them in pairs on the bottom of slide out shelves or applications that don’t use a drawer front. I would never use a single one because stability would be an issue. If you get a lot of weight on one side, it would rack on you and affect the ability to slide smoothly.
-- I don't make mistakes, only design changes....www.dgmwoodworks.com
View hasbeen99's profile
hasbeen99
183 posts in 3440 days
#6 posted 02-10-2010 10:50 PM
I used a couple on an under-sink trash bin I made a few years ago. It seemed fine for a while, but now I’ve noticed there’s a considerable sag when fully extended. When I rebuild it, I’ll either use under-mount glides or try a different configuration.
-- "The only thing that counts is faith, expressing itself in love." --Galatians 5:6
View JAGWAH's profile
JAGWAH
929 posts in 2985 days
#7 posted 02-10-2010 10:54 PM
I have used them often that way. I have 4 spice drawers in my own kitchen that are an 8th inch apart using the guides this way. Saved a lot of space.
-- ~Just A Guy With A Hammer~
