Learning Tower/ Kitchen Helper.... Help!
Forum topic by BanksWorkshop posted 02-08-2016 01:37 PM 559 views 0 times favorited 2 replies Add to Favorites Watch
View BanksWorkshop's profile
1 post in 771 days
02-08-2016 01:37 PM
Topic tags/keywords: learning tower wobble legs question
This is my first post on Lumberjocks.
I am building this learning tower from Ana White ( ) and for some reason the tower is not square. It also wobbles.
I have been troubleshooting the wobble problem and have not come to a solution.
If anyone can help, that would be great.
Thank You
-- Banks Workshop
2 replies so far
View dhazelton's profile
2719 posts in 2228 days
#1 posted 02-08-2016 02:01 PM
If it’s not square chances are good that it’s also racked and that’s why it wobbles. If you are using a framing square of some kind I’d suggest you try another one on the joints you made – I would wager that they are off. Telling us what kind of joints you used would help. If you are doing mortise and tenon and things aren’t tight it will move when you clamp it up.
View rwe2156's profile
2837 posts in 1412 days
#2 posted 02-08-2016 02:33 PM
How did you build it?
Its the saw cuts or the assembly process (or both) in which case errors multiply with each step.
Check your saw for square and square parts up before fastening.
And check everything with a square that is square!!
