post /removal
Forum topic by bill merritt posted 02-09-2010 11:01 AM 1703 views 0 times favorited 25 replies Add to Favorites Watch
View bill merritt's profile
bill merritt
203 posts in 3284 days
02-09-2010 11:01 AM
Has anyone removed one of those round post (lolly column) it’s right in center of shop. In the way for my TS mainly. It’s about 15’ at point where post is, just wondering what type beam would I need to put in to take its place?
-- Bill Merritt -Augusta Ga. woodworker
25 replies so far
View Sawkerf's profile
Sawkerf
1730 posts in 3064 days
#1 posted 02-09-2010 04:34 PM
Bill -
Get a good contractor (and maybe a structural engineer) to help you with this.
That column is carrying structural loads that must be identified so a new support system can be designed and built to carry those loads after that column is removed. It’s almost certainly do-able, but it needs to be done correctly.
Most of the sagging structure problems I’ve seen were the result of somebody with no understanding of structural engineering whacking out structural members. Sometimes they get lucky, but more often the building shifts or sags. In rare cases, they bring the building down.
View SnowyRiver's profile
SnowyRiver
51457 posts in 3476 days
#2 posted 02-09-2010 04:51 PM
I agree with Sawkerf. It pays to get the right scoop on whats needed. Is this in your house, or is it a garage? It can be disasterous to remove a support structure and not replace it with one that’s heavy enough since even the slightest sag can affect not only the integrety of the building, but your floors and door and window operation among other things.
-- Wayne - Plymouth MN
View miles125's profile
miles125
2180 posts in 4001 days
#3 posted 02-09-2010 04:57 PM
I’d like to see you solve it by building what looks like a suspension bridge assembly on the shop roof :)
-- "The way to make a small fortune in woodworking- start with a large one"
117090 posts in 3572 days
#4 posted 02-09-2010 07:07 PM
I am a contractor and I would never suggest remove a support with out looking at it in person and taking under consideration the load and spans involved.
#5 posted 02-09-2010 07:08 PM
I am a contractor and I would never suggest removing a support with out looking at it in person and taking under consideration the load and spans involved.
View unisaw2's profile
unisaw2
209 posts in 3031 days
#6 posted 02-09-2010 09:15 PM
I agree with all above, get a good contractor or structural engineer to look at it.
-- JJ - Northern Illinois
View dryhter's profile
dryhter
74 posts in 3599 days
#7 posted 02-10-2010 10:14 PM
’’just wondering what type beam would I need to put in to take its place?’‘ Listen to what others have said get the advice of an architect or structural engineer
But you are just wondering,and you need to know something about what you are going to be asking about. Your post is already supporting a beam, and only by calculating the various loads and stress upon this beam can any changes be made. But in the simplest scenario, after calculations have been made, a steel beam will be selected and installed. A steel beam is designated by widthXheightXLbs. per foot. The Lbs.per foot =/or relates to the thickness of the webs making up the beam (ie. 1/4 in., 3/IN., 1/2in., etc,etc,). The strength (not sagging)of the beams comes from it’s height, but in most cases a heavier web can make up for less height(sometimes).
Next comes the install, beams are heavy, keep that in mind, if you are lucky enough to have the headroom you might be able just to install the new beam under the old beam, but probably not, so you will have to take out the old beam first. Temporary walls will need to be built, about two feet out along each side of the beam to support the load of the beam being removed, and check to see if additional temp. support walls are to be built on other floors above this temp. wall. Now you can cut out the mid-span support(lolly column) and start cutting out the end supports. If the existing beam is wood just cut it up into pieces, taking care not to destroy the joists (cut the nails don’t even try to pull them,the old dry wood will splinter).
If you are able, cut a hole in the side of the building, at the bottom as close to the floor as possible, and slide the beam in to place underneath where the old beam was. If you can’t do this then you have to get the beam into place preceding building of the temp. walls. I believe the beam must bear a minimum of 1 3/4 in.(you should check on that),( I usually have the beam cut 11/2in. smaller than what the actual measurement was). Nail a plate(2X materialX the size of the flange of the beam) across the underside of the joists where the beam will finally rest. Get the beam into the pocket where the beam supports will be, now all you have to do is somehow get the beam lifted up into place and temporarily supported (securely temporarily supported), you still need to get the beam into perfect place and jacked up tight to the plate that was installed on the joists.
Once the beam is in place and is jacked up into place and taking weight up off the temporary walls, cut 2X supports for the beam support pockets,fill as required so that the supports end at the beam flange edge. Fill behind the beam and run the next supports on each side of the beam up to the plate and then in-fill to the next stud on each side (supposedly to keep the beam from tipping).
Don’t be surprised if the new beam does not jack up tight when in place. almost all beams settle or sag over time , especially wood. Use metal shims(that can be purchased where ever the beam is bought, of course you don’t know how many you will need), in a pinch you can use hardwood end grain shims cut to fit, or just jack that beam into place where you want it and deal with the cracked drywall and disturbed door openings.
Slowly remove the jacks and then remove the temp. walls should take a day, good luck!
-- Chips and Shavings/ see you at WWW.underconstructionlive.com
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3110 days
#8 posted 02-10-2010 10:40 PM
that is one of those things you never do unless you are very skilled
get a contractor who has done it a few times before i have seen
some big failer when people try to do it DIY they still pay for a house
that they don´t have
Dennis
View Dennis Fletcher's profile
Dennis Fletcher
467 posts in 3050 days
#9 posted 02-10-2010 10:56 PM
I am a contractor and house designer. i do the math to calculate these beams and trust me, what you are looking to put in to replace the post would be very big and heavy. It may require you to add mor support to the exterior walls and may take quite a lot of headroom.
If it is a garage, it is often easier and cheaper to have a company design and build trusses that require no beam and do a rehab, ripping off the old roof and putting on a new one.
I’m not joking about it possibly being cheaper, either.
-- http://www.ahomespecialist.net, Making design and application one. †
Sawkerf
#10 posted 02-11-2010 01:06 AM
Dennis -
I’m a contractor too, and a licensed PE and one very important bit of info Bill left out was where this post is. I had visions of a basement under a two story house, but it could be a garage or a shed. Whatever he has, he definitely needs some professional input.
Dennis Fletcher
#11 posted 02-11-2010 01:19 AM
Sawkerf,
Your right, I just assumed, based on where I see most shops. Wow, how much worse if it were your scenario.
I have been on the receiving end of a roof collapse, not fun. Fortunately, I was in a spot that was protected, talk about scared out of my, well, you can just guess.
Removing a post and making a beam larger is dangerous, even for a PE. I’m sure Sawkerf would agree.
Why don’t you look at exchanging the single post for 2 posts, giving you room, but causing the load to be split.
Again, though, hire someone qualified to run the numbers. A PE is the only one I would suggest. Let them crunch the numbers and let a contractor do the work.
Dennisgrosen
#12 posted 02-11-2010 01:22 AM
Sawkerf
that was thenearly the same visons I had maybee my shop is inmy basement
and I have a house in two plans
but I have seen the result of those things if it has not being done the right way
and you are right it cuold even be a little shed
View Enthalpy's profile
Enthalpy
44 posts in 3037 days
#13 posted 02-11-2010 02:04 AM
Work around the post..it’s cheaper (DBeener that’s 2 words)
Sawkerf
#14 posted 02-11-2010 07:28 AM
Well, glivingston, I am offended by your statement. Yes, some contractors will cut corners, but your statement paints all of us with the same brush. I’m sorry you’ve had bad luck with your contractors, but some of us (I like to think most of us) try our best to do the job in an ethical and professional manner.
So far, the posts to this thread have unanimously urged Bill to get professional help with his problem. Are you suggesting that we’re all cutting corners to make a buck??
dryhter
#15 posted 02-11-2010 04:53 PM
GEEEEEEEEEEESH, glivingston I agree with Sawkerf, If you got scammed at some point, then shame on you. You did not do your due diligence in hiring a reputable contractor,all you need to do is ask for references, current and several years old. Call those references.
I have been in business for a long time and big job or small I strive for customer satisfaction. Their referral might possibly be my next job and yes it is all about making a buck. In thirty years of business I have had to leave 5-6 customers unHappy. I figure thats not a bad average. It is always about the money, my unhappy customers mostly fell into one of two groups, those with great expectations / little pocketbooks and those that could do it better themselves / but don’t have the time. And after each one of those unHappy customer experiences I would curse myself for taking the job in the first place because usually I had a gut feeling to begin with. Now when I get that feeling I make my apologies and regretfully(yea, right) I can’t do your project.
I have often thought there should be an Angie’s List for contractors to check on customers.
