Eliminating side to side movement in miter gauge.
Forum topic by 716 posted 02-07-2016 09:02 PM 1499 views 0 times favorited 27 replies Add to Favorites Watch
View 716's profile
716
502 posts in 821 days
02-07-2016 09:02 PM
I know most of you would say “Just buy Incra”.
The stock table saw miter gauges are actually quite good for the most basic stuff like cutting at 90 or 45 especially if you attach a small fence to the back. However there is one thing that kills it. The side to side movement is around 1mm making it useless. You set your piece for a cut at certain size, than the miter gauge moves and you have hopefully undercut it, so you still can fix it, If you overcut, then it goes into scrap.
I have no idea why manufacturers even bother including a miter gauge if they are not willing to take measure against the side to side movements. Is it something that some folks managed to take care of themselves ?
-- It's nice!
27 replies so far
View joey502's profile
joey502
520 posts in 1423 days
#1 posted 02-07-2016 09:15 PM
Does the miter gauge not have set screws in the bar to adjust the miter slot fit? My stock miter gauge has the set screws, but I did buy an aftermarket that is much better.
joey502
#2 posted 02-07-2016 09:16 PM
Or, buy an Incra.
bandit571
19192 posts in 2588 days
#3 posted 02-07-2016 09:26 PM
Heard about using a center punch, make a few dimples on one side of the bar.
Also depends on the style of the bar, too. Does it have the tab out on the end that runs in grooves? Or, just a plain steel bar?
View TheFridge's profile
TheFridge
8882 posts in 1391 days
#4 posted 02-07-2016 09:39 PM
Drill and tap. Brass screws
View dhazelton's profile
dhazelton
2687 posts in 2201 days
#5 posted 02-07-2016 09:47 PM
Could put a strip or two of electrical tape on one side.
View MadMark's profile
MadMark
979 posts in 1358 days
#6 posted 02-07-2016 10:12 PM
None of it is Craftsman is it? Their ts miter slots are .010” under – .740” vs .750” on a ‘real’ saw … if you use a Sears miter gauge on a real saw it’ll be sloppy as hell.
M
View Redoak49's profile
Redoak49
3076 posts in 1893 days
#7 posted 02-07-2016 11:41 PM
Drill and tap on side in a couple of places and pot in nylon screw/bolt.
View 716's profile
716
#8 posted 02-08-2016 12:07 AM
This seems so easy and inexpensive to implement, Should be there by default even on the cheapest saws.
-- It's nice!
View hotbyte's profile
hotbyte
991 posts in 2880 days
#9 posted 02-08-2016 12:19 AM
My Delta 36-725 has set screws in miter gauge bar to adjust slop.
Another tip I’ve read is to run aluminum HVAC tape down edge of bar.
woodbutcherbynight
3952 posts in 2314 days
#10 posted 02-08-2016 02:38 AM
Like many others I used the factory miter gauge and as suggested I did drill and tap mine and put adjustment screws in it. Recently I made a cross cut sled seems to me to be much more accurate. My .02 cents worth anyway.
View Nubsnstubs's profile
Nubsnstubs
1245 posts in 1635 days
#11 posted 02-08-2016 03:46 AM
Take the miter guide, lay it flat on your saw top, and hit each end with a ball peen hammer. Try to put it back into the slot. If it doesn’t go, file off a little of the mushroom until it goes into the slot. When you get to the other end, do the same if it’s shroomed. If it didn’t mushroom enough, hit it again, or until it won’t go into the slot. Do the file thing until it fits snug, but not tight…... better than getting an incra. ............ Jerry (in Tucson)
View bigblockyeti's profile
bigblockyeti
4984 posts in 1625 days
#12 posted 02-08-2016 03:50 AM
I welded a few spots on the side on one of my sloppier gauges after taking it apart and put it on a surface grinder to get the width about 0.0013” less than the slot on my table.
116902 posts in 3482 days
#13 posted 02-08-2016 04:15 AM
a strip of metal duct tape usually works great.
View splintergroup's profile
splintergroup
1873 posts in 1127 days
#14 posted 02-08-2016 03:10 PM
Jerry (Nubsnstubs) and big block have good solutions if you have the equipment or the adjustment is minor.
I have an Incra and basically the miter bar sucks. The problem is my table saw (Unisaw) has the typical oversized Delta miter slot and aftermarket manufactures like to make there stuff fit the lowest common denominator, in my case the Incra fits the undersized slots in an old Craftsman saw perfectly.
The Incra uses expanding nylon disks to adjust. This is fine, but my disks regularly wear down and the slop returns. The disks also are spaced far apart so there are areas in the miter bar travel that don’t get proper side to side support.
My first solution was to drill a number of holes across the width of the bar, thread them, then install (with lock tight) some set screws. This allowed a perfect width adjustment. I was a bit worried about the set screw heads eventually gouging into the miter slot sides so I swapped in some of the ball bearing tipped screws. These have a small spring inside that allows the bearing to retract when under force, basically allowing the miter bar to be ‘spring loaded’ to one side of the slot with bearings acting as one of the sliding surfaces.
Eventually I plan on just milling down a piece of bar stock and replacing the Incra bar (the Incra head is fantastic).
My factory Delta miter has the usual near-useless head, but the bar fits the slot perfectly (hummmm…...)
View xeddog's profile
xeddog
177 posts in 2912 days
#15 posted 02-08-2016 07:29 PM
Several good ways, but what about some Teflon tape down one side?
Wayne
