tuning a cheap dovetail saw
« back to Hand Tools forum
Forum topic by harum posted 02-07-2016 05:02 AM 962 views 0 times favorited 9 replies Add to Favorites Watch
View harum's profile
harum
284 posts in 1607 days
02-07-2016 05:02 AM
I am looking for an advice on how to get this dovetail saw working: Two Cherries/ Robert Larson, 10”, push stroke. It cost me $15 and wasn’t cutting well out of the box. I jointed it slightly, then sharpened with a XX slim taper file: please see the blade after sharpening on the photo with an inset at 2x zoom, the heel is on the right:
With sharp teeth, it cuts pretty well now, except that starting a cut is really hard because on the push stroke the teeth bite into the surface of the wood and don’t move, unless quite a force is applied, at which point I start loosing the control of the angles and the direction. Would resetting the saw help me with starting the kerf? Or should I sharpen the saw more?
Another thing: even though the brass back is straight, the blade is slightly curved along the length—how to fix this?
Would greatly appreciate any suggestion or reference. Thanks and best wishes, h.
-- "If you're not counting the ripples when throwing pebbles in the water, you're wasting your time."
9 replies so far
View David Taylor's profile
David Taylor
326 posts in 1051 days
#1 posted 02-07-2016 05:10 AM
You may want to try and add a bit of rake to the first couple-few inches of teeth. 90 degrees is correct for rip teeth, but tipping that back a few degrees at the toe may help you start a bit easier.
-- Learn Relentlessly
harum
#2 posted 02-07-2016 05:21 AM
Thank you, David! Will try adding a rake, and maybe some fleam, to the toe.
View TheFridge's profile
TheFridge
9249 posts in 1450 days
#3 posted 02-07-2016 06:10 AM
That would help. A very very light hand at the start will help as well.
I’m pretty sure you need to stone the sides of the teeth after sharpening. I found this very helpful.
http://www.vintagesaws.com/library/primer/sharp.html
View Tim's profile
Tim
3781 posts in 1925 days
#4 posted 02-07-2016 01:37 PM
- harum
If it came to you that way, return it.
If that’s not an option try this:
https://logancabinetshoppe.wordpress.com/2013/06/07/straightening-a-backsaw/
And this Paul Sellers video may help
https://www.youtube.com/watch?v=tzc4tQ5CRxk
If it were the back that was bent, try this:
http://lumberjocks.com/Brit/blog/30858
harum
#5 posted 02-07-2016 04:02 PM
Appreciate all the replies! Thank you for the references, Tim! Yes, it came with a straight back but slightly curved blade. I went to the nearest Woodcraft to see their selection of cheap dovetail saws; all their 20-40 dollar dovetail saws had curved blades, some really badly. I wanted to ask them about the bent blades but I had already irritated them enough by pointing to the rubbery plugs of polymerized tung oil in every bottle of their Woodcraft Tung Oil. So I just left without buying anything. Again.
There’s another thing: my every cut consistently arcs slightly to the left deviating from the straight line. I bought the saw through the internet, so returning it is not straightforward. Will try tweaking it and then practicing.
TheFridge
#6 posted 02-07-2016 04:18 PM
The arc is on the face of the board as you’re cutting down?
View bandit571's profile
bandit571
19718 posts in 2647 days
#7 posted 02-07-2016 04:19 PM
Too much set to the left side of the plate. Run a stone along the teeth on the left side of the saw. Go from heel to toe. Once or twice, make a saw cut to check if more is needed.
harum
#8 posted 02-07-2016 04:25 PM
TheFridge, yes, the arc is on the face when I cut down starting on the end grain. Bandit571, thanks for the tip.
harum
#9 posted 02-10-2016 03:29 AM
Bandit571, thanks for the suggestion; I ran a stone a few times on the left side and the cut straightened up. It’s no longer an arc. Interestingly, this also solved the problem with starting a kerf: it’s very easy now, like it should be.
